ianj Posted November 25, 2003 Report Share Posted November 25, 2003 Hi all, Looking for a wiring schematic for the 2003 Sherco.......a mates 290 has lost it's spark.....and from what I can gather it's a bit of a rip-off paying some dude mega bucks to fix when it's gotta be something easy. Apparently, a common fault is the sensor behind the flywheel......any ideas!......I'm not averse to re-winding the damn coil if that's all it is! A schematic would help me troubleshoot. RYP & Sherco website have just about everything EXCEPT the actual wiring schematic. Ian. Quote Link to comment Share on other sites More sharing options...
the artist formerly known as ish Posted November 25, 2003 Report Share Posted November 25, 2003 Ian, I have had two lost spark, both times it was the plug lead wire, it screws into the coil and the plug cap, unscrew it from the coil and check for continuity or unscrew both and just check the lead then make sure you get it centered on both when you put it back togeather. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 25, 2003 Report Share Posted November 25, 2003 Ian I had a faulty backplate, one wire, guess it must have been Low Tension side from stator packed up. Quote Link to comment Share on other sites More sharing options...
ianj Posted November 25, 2003 Author Report Share Posted November 25, 2003 Hi, This bike is in Stonehaven, my pal Calum's bike. Bike was bought from Lewisport just a few weeks ago. They have referred us to some dude who can carry out repairs, but I'd rather have a look myself first. His previous Sherco (2000) has a similar problem and luckily I found a broken wire on the stator plate......no such obvious things on this one though. Anyone who can wind his own guitar pick-ups can surely wind a stator plate coil or two.... Ian. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 25, 2003 Report Share Posted November 25, 2003 Surely lewisport have some obligation? Quote Link to comment Share on other sites More sharing options...
bikespace Posted December 15, 2003 Report Share Posted December 15, 2003 See if this link is any good to you from Sherco's web site: http://www.sherco-moto.com/downloads/wayne...ing_diagram.pdf Cheers Bikespace Quote Link to comment Share on other sites More sharing options...
adam Posted October 31, 2004 Report Share Posted October 31, 2004 http://www.sherco-moto.com/downloads/wayne...ing_diagram.pdf Can anyone translate this wiring diagram to English cos I need help with my 2004 2.9 that won't spark? Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted November 1, 2004 Report Share Posted November 1, 2004 You probably don't need a diagram unless you're re-wiring. Just make sure all the connections are clean and tight. I put dielectric grease on everything. Take off the ignition cover and check for moisture. Try disconnecting the kill button. Quote Link to comment Share on other sites More sharing options...
