1972 ossa Six Day Replica rebuild
adam19871
Hi guys,
I have a six days replica that i found buried in a barn. After checking the stator, im not sure if i am getting good readings. From blue to ground, and black to ground, i am getting nearly 35 M ohms. Also, could any one tell me the correct size puller to remove the flywheel? Thanks.
No idea what the thread size is but if your flywheel is brass coloured it uses the same puller as the MAR or any other Ossa motoplat flywheel - as above, available from In Motion. They're R/H thread
