OSSA TR280 software.
papapitufo
  On 6/22/2018 at 11:02 AM, mge said:
hello everyone.
i dont know if this is the right spot to ask but have to start somewhere.
have a 2012 tr280i thats really hard to start. i have just purchased a diagnostic link cable but am not having any luck with getting the k-scan program.
not too many people to turn to in rural australia.
have done lots of reading these forums but still cant really put my finger on the problem. wanted to see what the ecu is reading before pulling anything else appart
thanks for any help .
mark.
Expand
I was able to start the first or second kick.
It is necessary to have a very clean filter, butterfly and admission.
I mix it at 0.6% (30cc per 5 liters)
It also helps to reset the tps.
I've mentioned it before- but I've made a mod that make the OSSA very easy to start.
 A small LiPo battery that is only triggered when you hold down a 'kill button' style switch. they 'wakes up' the ECU and also runs the fuel pump.  really makes a difference.
  • 3 months later...
Expand
Hi. im looking to make some adjustments to my tr 300i since adding a flywheel weight recently. would you be able to point me in the right direction for software plse lotus54?.. kind regards
Expand
It is a hardware addition.  Very simple.
A very small 12V LiPo battery is connected to a momentary switch. I choose to put it on the right handlebar, using a KTM style kill button. Installing it there means I take my hand off the throttle when pushing the button- so I don’t move the throttle when starting. That output from the switch is fed to the 12V + of the ECU connector. (- is connected all the time).  So when the button is pushed, 12V is applied to the system, running the fuel pump for a second or two. At least for me, it makes for much easier starting (even better than the ‘easy start’) and also is a LOT easier if you run out of fuel.
I posted a diagram here, I’ll find that and add the link.
Mark
Edited by lotus54
Mark
Expand
hi, Thanks, although my bike does not need this addition. I should have been more clear in my response, i am in need of the diagnostic software, i have tried with some sent by members here although i cannot get it to unzip through dropbox.  "torrent is not valid bencoding" is what i end up with using various winrar or rar file openers.. plse help ;(
Hello. Are there any members here on this thread able to help me. I am desperately trying to sort my bike out. Just needs fettling since adding my flywheel weight. So looking to get the software to attempt running the cable mod I have carried out.  A few members here have sent me links but I'm unable to get anywhere near opening them. If someone can help please fire away.
Kind regards
I have not had anyone say they couldn’t open the file from Dropbox so far.
Did you get a link from me?  It is too large to send via email and since I’m in the States putting it on a USB drive or something would be slow and a bit expensive. PM/Email me and we can try my link, or come up with another solution.
Mark
  • 1 month later...
Hello,
I am Italian but I have an Explorer 2015 in Tenerife.
it has only 1000 km more or less but it stopped and never started again.
2 mechanics here do not know what to do.
I would appreciate any suggestion.
I do not know much sbout motorcycles, I bought the ossa because it is 70 kg,
light for my campervan.
As of now I want to sell it, but if it does not start.....
In short I am looking for someone that might be or come to Tenerife who could help me.
Thank you.
Best,
Dario
 Tank you so much Papapitufo, I called the shop you suggested in grand canaria but they say they do not repair ossa  and tthey do not have the software .
 I think I will get the software and the cables myself, if I do not find any other option . Any other suggestion would be very welcome
  • 4 weeks later...
