Electronic ignition
Varlo
I've got 1 of their ignitions in mine, pretty sure the instructions were to set it up mid slot to start with & fine tune to suit if needed
Because you use the original flywheel the marks should line up at the standard firing point. I can look in about half an hour & let you know what the standard firing point is & check my instructions
  • 3 weeks later...
I've timed several engines, including 4 cylinder cars, and found it best to set it up by adjusting for best tick-over and slow running.   If you have clean running then who cares what the actual degrees are?   Could solve your splutters...
