TY mono pinky front box repacking.
340bulltaco
Hello there,
I cut a small piece out of the back of the box for a look-see and it is a real mess of packed solid gunge and carbon.
I've seen the very helpful pics from Searay175 on 03/11/16 (attached) but can't quite figure out the best place to cut the rear end of the box. There doesn't seem to be a lot of space to cut between the outlet and the mounting bracket like he did and it looks like that would be a real pain to weld up again.
Any words of wisdom would be greatly appreciated.
Wow, what an enormous amount of work you have put into that, both bikewise and writing -up wise. Thanks a million for sharing it.
The pics I found previously showed the rear of  the box cut off , but you have cut off the front, which seems much more sensible so I'll do it that way.
Many thanks again for sharing this huge amount of fascinating and inspiring information.
Best regards, George.:)
  • 4 months later...
