Cota 247 Fuel Tank... What are the options?
riffraffretro
I've done a fair bit of searching about here on TC and via Google, but can't seem to unearth a definitive answer.
My 247's fuel tank (21M frame number) needs attention: various bubbles in the gel coat, with a dodgy underside repair that doesn't look like it'll run the distance (it's 100% fibreglass and not the UK market alloy/fibreglass version). I was hoping to source a UK tank (alloy/fibreglass), as that appears (to my mind at least), to be the better option, but I cannot find anything available, anywhere! Anyone know of a supply? I guess the next best option would be to repair and seal the existing tank - anyone able to recommend a product that can be relied upon to actually do the job, keeping the ravages of ethanol and whatever else constitutes modern unleaded at bay - peeking down the filler neck of mine reveals a silver/grey coloured flaky/wrinkly looking deposit inside, which I'm assuming is from a previous repair attempt?
... Or, has anyone used a tank off of a different bike successfully, modified suitably for the 247? I see that Bultaco alloy tanks are readily available and wonder if there's something similar to the 247's tank out there that could re-purposed... without requiring the fabrication skills of a F1 engineer!
Thanks for any pointers.
Edited by riffraffretro
I'll be facing a similar problem on mine when I get to the tank. Plan A is to remove the damaged bottom of the tank section and glass in a new section. Plan B is to remove the bottom altogether and fit a smaller aluminium tank, then fit the original as a cover over it. Probably have to do something with the filler, but it would retain the original look and seat mount.
21 hours ago, cleanorbust said:
www.allensusedtrialsspares.co.uk
I'll look into that, thanks!  :thumbup:
I just learned of a guy that does custom oil tanks for Harley choppers from a buddy in Roswell.  I may talk to him and see if he would be willing to fab up a tank, then mod mine to fit over it.
Edited by brewtus
Chopper tank
The benefit of this method is the alloy tank you make can be quite rough.
