40 mm Marzocchi fork- cap tool
lotus54
I popped mine apart without one... I'm trying to remember how. I think I wrapped the caps in electrical tape a bunch of times then used a pipe wrench just enough to get them loose, after which you can unscrew them by hand. Fork caps really don't need to be more than hand tight, so putting them back together is no big deal, and afterwards they come apart easily with no tools.
Be careful with the internals, those forks are a nightmare.
EDIT: actually, I remember now. I didn't use a wrench, I used a hose clamp. Tightened it down so it was only covering the top cap, again with some electrical tape around the cap, then just unscrewed it by hand.
Edited by heffergm
