Cota 247 Footpeg Springs - Hell's Bells
riffraffretro
Just ordered a shiny new set of footpeg springs for my 247 (InMotion), which look nothing like anything I've fitted before (hooked ends).
Having just spent... ahem, far too long trying to fit them, can anyone help/provide a few pics? They're slightly different (left to right side), too.
Can't do a photo at the moment but from memory the "straighter" end of spring fits through a small hole in the frame bracket, the other through a hole in the underside of the footrest. The footrest bolt fits through the wound circular part of the spring, there should be a small bush to fit over the bolt there, inside the spring.
If you don't get sorted let us know and I'll manage a photo tomorrow.
Edited by cleanorbust
Thanks Cleanorbust... that explains the issues I experienced earlier. From your description, it seems that the bike has had aftermarket pegs fitted by the PO.
I'll likely buy a generic set of springs and run with those.
Cheers - I really appreciate your time explaining this.
