mussorijder Posted November 7, 2017 Report Share Posted November 7, 2017 Hey guys, I am new here and I picked up a 2006 rev 3 125 today. I did a test run and all was good but now I got home and the cluch doesn't work anymore, it is very light and does nothing. Anyone who has any idea? This is my first bike with a hydraulic cluch. Thanks. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted November 7, 2017 Report Share Posted November 7, 2017 It could have air in the clutch line- make sure you have a little gap in the lever pin to master cylinder piston. Also make sure to check if it uses mineral oil or DOT 4 Brake fluid. DO NOT use the wrong type! Quote Link to comment Share on other sites More sharing options...
mussorijder Posted November 7, 2017 Author Report Share Posted November 7, 2017 Thank you, I will look at it and replace the fluid there it is dark. Do I bleed the system with a vacuum bleeder or not? Quote Link to comment Share on other sites More sharing options...
mussorijder Posted November 15, 2017 Author Report Share Posted November 15, 2017 Thanks Lotus 54, I bled the system and now it works! 2 Quote Link to comment Share on other sites More sharing options...
