jimyam Posted November 12, 2017 Report Share Posted November 12, 2017 Thump from forks when lifting the front wheel . I have stripped the forks down and can find no faults any one any ideas Quote Link to comment Share on other sites More sharing options...
spen Posted November 12, 2017 Report Share Posted November 12, 2017 Oil quality and level?? Quote Link to comment Share on other sites More sharing options...
jimyam Posted November 12, 2017 Author Report Share Posted November 12, 2017 Oil Castrol 10 w 410 cc per leg Quote Link to comment Share on other sites More sharing options...
walter_neff Posted November 12, 2017 Report Share Posted November 12, 2017 (edited) My mate's Z had a similar problem, the forks were hydraulically locking as the oil level was too high despite draining and refilling with the correct quantity. Check the oil level by taking the top caps off and compressing the forks so that the springs are sticking out. Then make up a dipstick to check how far down the fork leg the oil level is (from the stanchion top edge). You want at least 150mm air space. Hope that helps. Edited November 12, 2017 by walter_neff Quote Link to comment Share on other sites More sharing options...
jimyam Posted November 12, 2017 Author Report Share Posted November 12, 2017 I will check for air gap and see how I get on thank you Quote Link to comment Share on other sites More sharing options...
