315 Pistons
nigel dabster
  On 11/26/2017 at 11:27 PM, dwayne said:
Hi all,
I got the new piston, it has only two rings with it, there are no identifying marks or makers name on it. Wrapped in a soft grease proof paper in a plain box.
I have sent it and the cylinder to Langcourts, i am waiting for them to get back to me with a price for fixing the cylinder and matching it to the piston. Fingers crossed.:unsure:
Expand
Hey Dwayne,
What piston did you get and where from and did it work ok
Edited by Andyb1987
Original piston kits still available:
http://www.splatshop.co.uk/montesa-cota-315r-piston.html
We had a couple of batches of the aftermarket piston rings and sent them back as the quality was terrible.  The only nice option we have found at the moment is not easy:
Dykes (Top Ring), just need gapping:
http://www.splatshop.co.uk/72-25-dykes-piston-ring-top.html
Flat Piston Rings - needs machining:
http://www.splatshop.co.uk/72-25mm-x-1-2mm-flat-piston-ring.html
On the flat piston rings there are a few issues that need to be sorted:
1. The internal diameter is about 0.5mm too small so needs machining out.
2. The pin cutouts are slightly too small so need filing out to 2mm wide and 1.8mm deep so it leaves 1mm to the outer edge of the ring.
3. The end gap is a little tight, so it will need checking and gapping to the right spec.
  • 3 weeks later...
Hi, No markings on the package at all, its working fine, it only has two piston rings just like a cr 250 piston. I sent the cylinder and the piston to langcourts so it was guaranteed to match.
Works fine, no issues.
https://www.sadboyracing.com/online-shop/dirt-bike-parts/#cc-m-product-6770788011
The racing one i got is out of stock but they still have the three ring piston kit which I can't vouch for, but there are few options.
Edited by dwayne
Info needed
  • 4 months later...
The original piston has a unusually long distance from the centre of the gudgeon pin to the top edge of the piston, on the original piston it is roughly 32mm.
Most other 250cc trials bikes are around 28-29mm so to keep the squish clearance correct and the port timing you'd need to measure both pistons very accurately and then get the bottom of your cylinder machined down to suit.
I've never done this so there may be other reasons why this not work, for example there might not be enough room for the front pipe to fit, there might not be enough material left to keep the coolant water ways the correct shape and the cylinder to frame mounting bracket would need altering to suit.
You'd also need to make sure the piston ring stop pins are at the correct angles, the piston skirt doesn't hit the crank when it's at BDC and it doesn't open the exhaust port at TDC. The radius on the cylinder head would need checking and you'd need to re-machine the cylinder head and gasket to suit the larger diameter piston.
So yes it may be possible but check everything first before making the plunge as it's not so easy to put material back on after.
Expand
Thanks for the reply I think thats to complicated for me it will be easier to buy the dykes ring etc and have them machined to suit.
  • 1 month later...
Bought a 315  kit off Albert at Sadboy. Not inexpensive, but not as dear as other providers. Its a  3 ring kit, Size "B" . Came with all gaskets, etc. Circlips, pin, rings, piston all individually packaged with Honda part numbers. Piston itself has "Gilardoni" cast on the inside, plus a part number. (Gilardoni make all of the Beta barrels / pistons & probably other makes too. Have never had any bother with Beta.). Quality looks fine.  Barrel off to Langcourts for Nikasil, & will no doubt have to take a great deal of care to ensure rings are in correct location, gapped, fitted right way up, etc, etc. Quite fortunate to have access to a Honda trained master Technician, so he will be doing the final fettling & build.
make sure its not one of their own, they have been know to give up after a couple of hours. If it is a gilardoni and a part number can you share these please?
Can you compare to the original and either post a photo side by side or let us know if its the same?
Does it look like the piston has been machined?
Sorry for all the questions but if it fits and works = major breakthrough in the 315 world!!!
