moi Posted November 16, 2017 Report Share Posted November 16, 2017 I've just been given a Sammy miller hi-boy, does anyone know what engines will fit? I have been offered a Tl250 will it fit? thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 16, 2017 Report Share Posted November 16, 2017 Probably need a lot more info, Miller made hi-boys for bultaco, yamaha and honda. Quote Link to comment Share on other sites More sharing options...
moi Posted November 16, 2017 Author Report Share Posted November 16, 2017 It’s the Honda frame, currently has an old cg engine in the frame? Quote Link to comment Share on other sites More sharing options...
b40rt Posted November 16, 2017 Report Share Posted November 16, 2017 On 11/16/2017 at 9:04 PM, moi said: It’s the Honda frame, currently has an old cg engine in the frame? Expand The cg is 125cc ? Physically a lot smaller than the 250 I'm sure. Quote Link to comment Share on other sites More sharing options...
moi Posted November 16, 2017 Author Report Share Posted November 16, 2017 So I’ve seen that there had been a special hi-boy 305, with a big bore tl250 engine, I cant find much information on the conversion etc so wanted to know if there was anyone with any knowledge around the complexities? Quote Link to comment Share on other sites More sharing options...
woody Posted November 16, 2017 Report Share Posted November 16, 2017 (edited) The Hi Boy frame sold by Miller was for the TL125 The Hi Boy 305 was a works bike and Miller's own development bike, not available to the public. The TL250 wasn't on sale in the UK through Honda so there was no market for a Hi Boy frame for the 250 Whether a 250 engine will fit the 125 frame I don't know, you'd have to offer it up and see. The 305 works bike was a long stroke which retained the 250 bore, it wasn't a big bore 250. Fraser did a frame for the TL250 which used a big bore for a 305 engine Edited November 16, 2017 by woody = 2 Quote Link to comment Share on other sites More sharing options...
petert Posted November 16, 2017 Report Share Posted November 16, 2017 I had a Yoshimura 305 kit on my enduro Cheney Honda. The motor was the old 250 single port 250 4v, very similar to the TL250 motor Quote Link to comment Share on other sites More sharing options...
knobbly Posted November 26, 2017 Report Share Posted November 26, 2017 There was a at least one tl250/305 made. I saw it for sale on ebay in the USA about 2 years ago. It was green and nothing like the works bikes. It was new(ish)!!!! and went for about £3k! You will need new engine plates made, but it can be done. This might be the same bike. http://veh-markets.com/motorcycles/honda/312147-honda-tl250.html Quote Link to comment Share on other sites More sharing options...
feetupfun Posted November 26, 2017 Report Share Posted November 26, 2017 On 11/26/2017 at 10:14 AM, knobbly said: There was a at least one tl250/305 made. I saw it for sale on ebay in the USA about 2 years ago. It was green and nothing like the works bikes. It was new(ish)!!!! and went for about £3k! You will need new engine plates made, but it can be done. This might be the same bike. http://veh-markets.com/motorcycles/honda/312147-honda-tl250.html Expand That one looks like a Fraser frame with a Bultaco front end (Sherpa T triples, Bultaco Betor forks and Alpina/Frontera front hub) 1 Quote Link to comment Share on other sites More sharing options...
woody Posted November 26, 2017 Report Share Posted November 26, 2017 On 11/26/2017 at 11:41 AM, feetupfun said: That one looks like a Fraser frame with a Bultaco front end (Sherpa T triples, Bultaco Betor forks and Alpina/Frontera front hub) Expand Yes, Fraser frame 1 Quote Link to comment Share on other sites More sharing options...
croatan Posted December 8, 2017 Report Share Posted December 8, 2017 The CG engine was preferred due to gearing. consult for more info http://www.kaila.net/tl125/ A TLR200 engine will fit where a TL125 engine will fit. The decompressor hump (activated by kick start) on the left side center case will be the determining factor if it will fit your frame. The TLR200 engine has a wider jump in gearing from 1st to 2nd than the CG. So nearly all single cylinder 2 valve honda motors 100cc to 200cc will fit where a CG was. Maybe some one can speak to the more modern engines like crf230 with electric start. A 150cc big bore TL motor was common in those frames, a Honda dealership in Raleigh sold them special order back in 1975-1976. Quote Link to comment Share on other sites More sharing options...
hendrik Posted December 22, 2017 Report Share Posted December 22, 2017 Had this fraser with big bore engine ( 380ccm), now somewere in Belgium.... Miller frame I only know with the TL125 engine, often with 145ccm, maybe the XL185 engine will be suit the frame.... 1 Quote Link to comment Share on other sites More sharing options...
moi Posted December 24, 2017 Author Report Share Posted December 24, 2017 Thanks for your help, two more questions: 1. I’m not sure if I should buy a tlr 200 engine, or build a Tl150? 2. Is the tlr 250 engine completely different in size to a tlr 200? Thanks Quote Link to comment Share on other sites More sharing options...
