gerwan71 Posted November 27, 2017 Report Share Posted November 27, 2017 Hi, I'm restoring an old 247 and I need to find a manual or specifications etc. The bike I assume is 70's but need to know how I establish the exact year of build? It has Montesa handlebars on it that are a bit weird as it has two throttles which I cant see why. Can anyone help with dating the bike? Explanation regarding handlebars? Workshop manual in English? Thanks Quote Link to comment Share on other sites More sharing options...
peetee Posted November 27, 2017 Report Share Posted November 27, 2017 Hi, frame & engine numbers, plus manuals can be found at http://www.southwestmontesa.com Hope this helps/ Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 27, 2017 Report Share Posted November 27, 2017 If you could post a photo or two that would help in dating the bike, and perhaps sorting out the handlebar mystery. I own a 247 and thought I knew a bit about them, but "two throttles"??? Do please tell more! 3 Quote Link to comment Share on other sites More sharing options...
brewtus Posted November 28, 2017 Report Share Posted November 28, 2017 I found Wilkipedia Spain a good resource - https://translate.google.com/translate?hl=en&sl=ca&u=https://ca.wikipedia.org/wiki/Montesa_Cota_247&prev=search Helped me identify the years of my 247 and 25 mini. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 29, 2017 Report Share Posted November 29, 2017 2 throttles? Left cylinder, right cylinder! Quote Link to comment Share on other sites More sharing options...
oldaz Posted November 29, 2017 Report Share Posted November 29, 2017 On 28/11/2017 at 0:25 AM, gerwan71 said: Hi, I'm restoring an old 247 and I need to find a manual or specifications etc. The bike I assume is 70's but need to know how I establish the exact year of build? It has Montesa handlebars on it that are a bit weird as it has two throttles which I cant see why. Can anyone help with dating the bike? Explanation regarding handlebars? Workshop manual in English? Thanks I bought on off USA ebay, same seller advertises every week, latest is ebay item 182929150577 The cota 247's don't come standard with 2 throttles, maybe you could follow the cables and see where they go? Or if it only has one cable to the carb, the PO may have kept a spare twist grip on the left side ?? The frame number should be on the side of the head-stock and start 21M******, it should also match the engine number stamped near the front engine mounting. You can check those numbers against year of production online at southwest site. As mentioned above, a picture of the twin throttles would be handy. Quote Link to comment Share on other sites More sharing options...
gerwan71 Posted November 29, 2017 Author Report Share Posted November 29, 2017 Hi Thanks for the replies, I have found matching numbers so if anyone has a look up that can find my bike i'd appreciate it. The handlebars also look different to what ive seen before so there are pictures of that also, The air box also looks different and I've put a picture up of the throttles on the handlebars and not sure at all why one is there????? Thanks if you can help. Quote Link to comment Share on other sites More sharing options...
oldaz Posted November 29, 2017 Report Share Posted November 29, 2017 From the numbers it looks like you have somewhere around '77 model. The number is about 4000 after mine and I know they made 4400 of my model, with the '77 being the next model after. The handlebars are genuine Montesa alloys, maybe original - I don't have experience with later models and there are always little differences. Like I thought the left twist grip is a spare for what-ever reason and this is not normal. The air box looks correct but has a small inlet spout that wasn't used on the earlier models - earlier models had a rubber 90 degrees between the air box and carb so the box sits horizontal - I've seen one other picture with the box mounted like yours. Looks like a nice bike. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted November 29, 2017 Report Share Posted November 29, 2017 Those bars are what came standard on the first (1976) and subsequent Cota 348s. They are 1" in the middle and stepped down to 7/8" for the lever mounts and grips. They have a nice shape but beware of unexpected failure. Mine looked perfect externally but broke unexpectedly in about 2014. 1 Quote Link to comment Share on other sites More sharing options...
fourex Posted November 30, 2017 Report Share Posted November 30, 2017 (edited) I think you have a rare Cota 247 Tandem/Trail that wore a 348 style tank, if so they apparently came out in July 1978 and started with 21M25307. I'm only basing this on info I've found on the net, not from personal experience. Refer attached pics. I think yours is the cota 247 Trail as shown bottom left in brochure shot. Cota 247 History 2 of 2.pdf Edited November 30, 2017 by fourex 1 Quote Link to comment Share on other sites More sharing options...
gerwan71 Posted November 30, 2017 Author Report Share Posted November 30, 2017 Hi Really appreciate the information you've given me as it will all help on the restoration, I've put some photos of the bike complete to see if anyone can tell me more about it. Thanks Gerwan 2 Quote Link to comment Share on other sites More sharing options...
fourex Posted November 30, 2017 Report Share Posted November 30, 2017 That is a very nice Cota 247 C, the very last model of 247 made, 1979 or 1980 at best. 2 Quote Link to comment Share on other sites More sharing options...
Jaf4fa Posted March 19, 2018 Report Share Posted March 19, 2018 Hi Gerwan, just got a workshop manual off a friend of mine. If you PM me your email I'll send it. Tried to attach to a PM but not possible. Cheers Quote Link to comment Share on other sites More sharing options...
