beta rev 4t - no spark
vectradam
this is the 'ignition generator check' as per an Evo 2013 4t manual (pg66) found on beta usa website under 'support'.....the check may be suitable for yours......
Disconnect black 12 way between the generator and CDI
Disconnect the white 2 way connector between the generator and the wiring
Black-White (pick-up) 320 ohm +/- 15%
Red-Blue (condenser charging) 15 ohm +/- 15% ......not sure the 2008 has a condenser/capacitor on it?
yellow-yellow (Service power supply) 0.6 ohm +/- 30%
after having stripped a Montesa 4rt and a beta 4t loom i'd say the wiring seems to be generally pretty poor on the beta so it could just be a bad connection. There are some wiring diagrams on the Beta usa sight that are readable but they are from later bikes -2014 onwards I think, but it may give you a clue...
good luck!
thanks very much for your help
tried new plug and removed kill switch but no change.
when you say 12 way connector thall1 i have a plug and socket  with 6 wires in and 6 out .
black - white    i have open circuit
yellow -  yellow - 0.6 ohms
red - blue - 15 ohms
so its looking like the pick up is finished.
anyone have any ideas of the best and cheapest solution ?
many thanks for your help
14 minutes ago, 2stroke4stroke said:
There are two places in the UK that can replace such components.  Easily found by a search as I don't think I am permitted to name them on the forum.
You are, no problem unless you own one of said businesses
