studio208 Posted December 11, 2017 Report Share Posted December 11, 2017 Hi everyone, if there's someone that might offer a thought on reading this plug it would be appreciated. There's a slight oil residue around the edge, but mostly carbon build up I think, mostly a dark grey colour. It's 6 hours old from a new Gas Gas 250. Motor runs well, no missing or popping, starts 2nd kick (most times) Most running time is only around 15 minutes squirts as my backs shot and wrist is busted. Any thoughts appreciated. Quote Link to comment Share on other sites More sharing options...
tshock250 Posted December 11, 2017 Report Share Posted December 11, 2017 Needs a proper run out, 15 minute sessions aren't enough to get engine properly hot enough for a true plug reading, also your exhaust will be starting to fill with unburnt oil. 1 Quote Link to comment Share on other sites More sharing options...
studio208 Posted December 11, 2017 Author Report Share Posted December 11, 2017 On 12/11/2017 at 10:30 AM, tshock250 said: Needs a proper run out, 15 minute sessions aren't enough to get engine properly hot enough for a true plug reading, also your exhaust will be starting to fill with unburnt oil. Expand Thank you, I was wondering if it would be an idea to run a hotter plug and lean it out slightly? Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 11, 2017 Report Share Posted December 11, 2017 I would be more concerned on what oil at which ratio. Quote Link to comment Share on other sites More sharing options...
tshock250 Posted December 11, 2017 Report Share Posted December 11, 2017 Good point, but I don't think it matters what oil/ratio hes using, his bike is going to get choked up bad style if its not even getting warmed up. Quote Link to comment Share on other sites More sharing options...
faussy Posted December 11, 2017 Report Share Posted December 11, 2017 (edited) 15 minutes is well long enough to get a bike warm and for a plug reading. Dont know what the running time has got to do with unburnt oil in the silencer. The state that plug is in i doubt if he run the bike continuously for a week it would look any better! Edited December 11, 2017 by faussy Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 11, 2017 Report Share Posted December 11, 2017 Depends on his throttle control. In 5 minutes the bike can get plenty warm with the right attidude, 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted December 11, 2017 Report Share Posted December 11, 2017 (edited) Agee, even light riding the fan is usually on within 5 minutes, 10 minutes top. A bike left at tickover for 15 minutes still shouldnt be that sooted oiled up Looks too rich to me, as opposed to too much oil Edited December 11, 2017 by faussy Quote Link to comment Share on other sites More sharing options...
studio208 Posted December 11, 2017 Author Report Share Posted December 11, 2017 I ran light for first few hours, then medium throttle & harder while breaking it in. Fan running more often than not which is expected. Quote Link to comment Share on other sites More sharing options...
faussy Posted December 11, 2017 Report Share Posted December 11, 2017 (edited) Definitely looks rich. Id expect a bike that has a plug like that to run noticeably lumpy or nearly oil up. You could lean the mixture, but be very careful because the last thing you want is a new bike running too weak! Usually in the cold weather bikes need a richer mixture, so again, kind of unusual. Edited December 11, 2017 by faussy Quote Link to comment Share on other sites More sharing options...
collyolly Posted December 11, 2017 Report Share Posted December 11, 2017 Not too clear whether this is a brand new bike,or new to you, but that is a very good photo of a very bad plug ! I would check the air filter, if that's been soaked in oil then the bike would run far too rich. I imagine to oil up like that it must feel like it's on the choke all the time, can you give a clearer history of the bike as something is very wrong if that's all brand new. Quote Link to comment Share on other sites More sharing options...
shakennstirred Posted December 11, 2017 Report Share Posted December 11, 2017 To me, it looks like way to much oil. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted December 11, 2017 Report Share Posted December 11, 2017 That plug is sooted up far more than its oiled up so probably nothing to do with oil to fuel ratio. Before I gave any advice I would need to know 1) Oil to fuel ratio and type of oil 2) What sort of use have you been giving the bike - pottering or hard running 3) Plug make and grade 4) Typical air temperature when you have been riding the bike 5) Time with cold start enrichment on 6) Condition of the air filter In past I have seen bikes that run maybe a shade rich (but perfectly acceptable) in summer but have given the same plug conditions you have when used for short runs in the type of weather (around freezing) that we are having in UK at the moment. Quote Link to comment Share on other sites More sharing options...
pschrauber Posted December 11, 2017 Report Share Posted December 11, 2017 Two things come in my mind when I look at the plug in my experience: - engine runs too rich and get's too little air in general, (cleaning the air filter and just use very very little filter oil) - bad oil seals at the crank so the engine is sucking gear oil, thus the sooting and plenty of oil in general. How does the exhaust vapors smell after two stroke oil or more towards burnt motor oil? Quote Link to comment Share on other sites More sharing options...
studio208 Posted December 11, 2017 Author Report Share Posted December 11, 2017 (edited) 1. Yes, the bike is brand new. 2. Filter's clean and not over oiled 3.The exhaust smells rich more than burning oil, more smoke then I would expect however, & smells like choke is on when running, however it isn't. 4. Oil to fuel ratio is 1.5% with Global Racing Oil - Moto2T Off Road 1 5. bike use is mostly pottering. 6. Ambient temp around 27c in Brisbane Au. 7. Time with choke on, a few seconds only to start bike when cold. 8. Plug - NGK-R (BPR5ES) It's the worst looking plug I've ever seen & is concerning for a new bike. Edited December 11, 2017 by studio208 additional info Quote Link to comment Share on other sites More sharing options...
