pancho247 Posted December 11, 2017 Report Share Posted December 11, 2017 Serious question........ whats the best way to keep the inside of your helmet clean? Is there any products to keep it fresh. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted December 11, 2017 Report Share Posted December 11, 2017 Cedar wood chips in a sock stuffed inside as soon as you stop riding can help a lot. Remove and clean the liner on a regular schedule. some have used different forms of alcohol, including Vodka. (Most of the time it takes more than once to get it back to normal and being consistent after that to keep it that way. Good luck. Quote Link to comment Share on other sites More sharing options...
cabby Posted December 11, 2017 Report Share Posted December 11, 2017 32 minutes ago, jonnyc21 said: Remove and clean the liner on a regular schedule. I canny believe that even has to be said Quote Link to comment Share on other sites More sharing options...
canada280i Posted December 11, 2017 Report Share Posted December 11, 2017 I have nothing to add but had to click on the topic because of the subject line 2 Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted December 12, 2017 Report Share Posted December 12, 2017 2 hours ago, cabby said: I canny believe that even has to be said Not sure I needed to say it but always best to cover the basics... 1 Quote Link to comment Share on other sites More sharing options...
tricky dicky Posted December 12, 2017 Report Share Posted December 12, 2017 Putoline amongst others sell a helmet sanitiser which is foam in an aerosol. That works well but the lining still needs removing regularly and washing. Quote Link to comment Share on other sites More sharing options...
guy53 Posted December 12, 2017 Report Share Posted December 12, 2017 I use Lysol between stripping and washing, I don't like it when I can call my helmet and it crawl to me by itself. Guy Quote Link to comment Share on other sites More sharing options...
pauls320 Posted December 12, 2017 Report Share Posted December 12, 2017 Its also a good idea to not leave it laying on the floor or ground if there are dogs present.. Quote Link to comment Share on other sites More sharing options...
spen Posted December 12, 2017 Report Share Posted December 12, 2017 Baby shampoo..... Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted December 12, 2017 Report Share Posted December 12, 2017 43 minutes ago, spen said: Baby shampoo..... Which is what Arai recommend. Quote Link to comment Share on other sites More sharing options...
jsp Posted December 13, 2017 Report Share Posted December 13, 2017 i soak mine in milton one tablet to about 10lit of water in a big bucket leave it to soak for 30 mins and then do the same in clean water and jobs a good en, as its the bactria that causes the smell, you also dont need to strip the helmet to do it. I also try and dry it after each ride and not leave it wet or damp Quote Link to comment Share on other sites More sharing options...
maggar Posted December 14, 2017 Report Share Posted December 14, 2017 Why do you want a clean helmet? It's trials, I usually start sweating like a Geordie at a quiz before I've ridden the first section. There's little point in starting off with a sweet smelling lid. Chuck it in the garage all sweaty and wet and chuck it back in your van when you go to the next trial. With any luck the mushrooms will drop out on the way. 1 1 Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted December 14, 2017 Report Share Posted December 14, 2017 5 hours ago, maggar said: .... sweating like a Geordie at a quiz .... Quote Link to comment Share on other sites More sharing options...
bob_m Posted January 17, 2018 Report Share Posted January 17, 2018 Soaking in about 1 gallon of warm water with 1/2 cup of Baking soda and some laundry detergent works for me. Hang to dry exposed to direct sunlight. I then spray liner and helmet with "helmet fresh cleaner", a product available on ebay. It even sanitized my dirty mind, fortunately that is only temporary. Quote Link to comment Share on other sites More sharing options...
blueflag Posted February 19, 2018 Report Share Posted February 19, 2018 Big bucket with a solution of laundry liquid, Bold or similar. Worked a treat on mine... Quote Link to comment Share on other sites More sharing options...
