349 rear wheel bearing size?
turbofurball
Not sure about size but knock them out carefully, you may find two on the drive side and just the one on the other side. Measure the inside diameter of the hud where the bearing fits. Measure the outside diameter of the removed bearing/s. Measure the inside diameter of the bearing and the wheel spindle exactly where the bearing will slide to. Google Simply Bearings check the measurements on their easy to use site and order. Every time I have used them they have delivered the next day and very respectsble prices to. There are other bearing suppliers I’m just passing on my experience for you benefit. Change the seals as well and use clean grease. If you buy sealed bearings (they have their own sealing arrangement) and will last longer in the long run. Hope this is useful to you.
Edited by section swept
Additional material added.
