trapezeartist Posted December 18, 2017 Report Share Posted December 18, 2017 I was muttering to myself about Beta bolting onto plastic while out in the garage the other night. The plastic shield over the gearbox sprocket is held on with two small bolts into the crankcase which (I think) also hold things together in the crankcase. And one of the two bolts holding the front brake caliper also holds the plastic disc shield in place. That's a biggish bolt (M10?) that's reacting brake torque so you really don't want that one working loose. Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 18, 2017 Report Share Posted December 18, 2017 40 minutes ago, trapezeartist said: And one of the two bolts holding the front brake caliper also holds the plastic disc shield in place. That's a biggish bolt (M10?) that's reacting brake torque so you really don't want that one working loose. Metal inserting plastic shield ? Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 18, 2017 Report Share Posted December 18, 2017 (edited) 3 hours ago, oni nou said: Plastic disc guards usually have a metal insert that stops the plastic being crushed and distorted and enables the head of the bolt that screws into the calliper to clamp tightly to the metal surface of the metal anti- crush insert. Echo .... Edited December 18, 2017 by b40rt Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted December 18, 2017 Report Share Posted December 18, 2017 7 hours ago, oni nou said: Plastic disc guards usually have a metal insert that stops the plastic being crushed and distorted and enables the head of the bolt that screws into the calliper to clamp tightly to the metal surface of the metal anti- crush insert. Usually, yes. But not in Betaworld. Quote Link to comment Share on other sites More sharing options...
guidobetaevo300 Posted December 19, 2017 Author Report Share Posted December 19, 2017 in the meanwhile my dealer had contact with Beta Italia and although its no waranty anymore as a new conrod wasnt in there warehouse the'll send a new crankschaft with 50% reduction. i cross my fingers to know what the totaly cost will be ... 1 Quote Link to comment Share on other sites More sharing options...
