MAR folding tip shift lever???
pmk
I see In Motion offers a tip assembly that could possibly be fitted to the oem shift lever.
More likely would prefer to find a common shift lever with the same spline shaft diameter and fit that could simply install easily.
Anyone ever found a worthy replacement?
1 hour ago, fourex said:
https://www.francetrialclassic.com/en/kick-start-footrest-tensioners-etc/2248-ossa-alloy-gear-lever-with-folding-end.html
Not exactly a great fit due to not hugging the cases closely enough, roughly a 20 mm gap on my '74 MAR but spline is ok.
Any chance you have a photo of the shifter installed that you could share?  I assume the 20mm gap is between the shifter itself and the screw heads?  Or is it 20mm between the small cover and the shifter?
Thank you for the link.
