jimyam Posted December 31, 2017 Report Share Posted December 31, 2017 I need a clutch casing for my 1988 ty mono .Rocking ? poo to find if any one can help ? Quote Link to comment Share on other sites More sharing options...
thai-ty Posted January 1, 2018 Report Share Posted January 1, 2018 I'm after a plastic fuel tank. Prices seem to be going mental for the ty mono. I've missed two on Ebay because they've gone for TWICE what I thought they would. Best bet in your case is probably buying a complete motor or basket case and having useful other spares. Quote Link to comment Share on other sites More sharing options...
bashplate Posted January 1, 2018 Report Share Posted January 1, 2018 jimyam...can you get it welded? Quote Link to comment Share on other sites More sharing options...
jimyam Posted January 1, 2018 Author Report Share Posted January 1, 2018 The casing is way to bad the kick start shaft done the damage broke the casing to bits not good Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted January 1, 2018 Report Share Posted January 1, 2018 Have you tried Richard Allen ? Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 1, 2018 Report Share Posted January 1, 2018 Perhaps consider the following. John Shirt and Nigel Birkett both used to get ignition flywheel casings cast for TY monos and the retail price was less than £25. Perhaps you could get a clutch case made. It would not be cheap but a good quality aluminium sandcast case should last a long time and would be weldable. Perhaps using TC or ebay a group of TY owners could get together and have a batch made. There are plenty of companies that can do one off or small batch casting and the TY case is simple to machine. Another option would be to have one fabricated out of aluminium rod and sheet, if you have any interest in this option I can give further details how its done. Quote Link to comment Share on other sites More sharing options...
thai-ty Posted January 2, 2018 Report Share Posted January 2, 2018 Stator flywheel ignition cover is not the same as the clutch cover. Hell, you could machine one out of billet aluminium, or weld an end on some tube. Clutch cover completely different matter. 1 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 4, 2018 Report Share Posted January 4, 2018 I am well aware the ignition flywheel cover is less complex that the clutch cover, that is not the point. If jimyam contacts Birks or JS they would probably tell him where they got the castings done and he could get a clutch casing priced. I do not know the price of a new OEM TY casing but I assume it is similar to a TYZ clutch case which was £400 plus before the recent fall in the £. A fabricated cover may not look quite right but it would do the job and be tougher / more repairable than the original, price would probably be around £300. An alternative would be to glue (JB weld) his case together then assuming it fits, get it measured on a CMM and then machined from billet. Considering you can get an 18 inch car wheel machined from billet for under £1000 then a much smaller item like a clutch casing might be a price jimyam considers acceptable. A machine shop I used to use machined items of similar size and complexity to a clutch casing for £60 to £90 (in 316 stainless or P20) On top of that you would have to add a programming charge of about £60, a tooling up cost of about £60, the billet cost and the CMM charge. Quote Link to comment Share on other sites More sharing options...
jimyam Posted January 4, 2018 Author Report Share Posted January 4, 2018 dadof2 I have taken my damaged casing to machine shop to see what can be done and asked the guy to price me for making one . Keep you posted ? Quote Link to comment Share on other sites More sharing options...
thai-ty Posted January 5, 2018 Report Share Posted January 5, 2018 22 hours ago, dadof2 said: I am well aware the ignition flywheel cover is less complex that the clutch cover, that is not the point. If jimyam contacts Birks or JS they would probably tell him where they got the castings done and he could get a clutch casing priced. I do not know the price of a new OEM TY casing but I assume it is similar to a TYZ clutch case which was £400 plus before the recent fall in the £. A fabricated cover may not look quite right but it would do the job and be tougher / more repairable than the original, price would probably be around £300. An alternative would be to glue (JB weld) his case together then assuming it fits, get it measured on a CMM and then machined from billet. Considering you can get an 18 inch car wheel machined from billet for under £1000 then a much smaller item like a clutch casing might be a price jimyam considers acceptable. A machine shop I used to use machined items of similar size and complexity to a clutch casing for £60 to £90 (in 316 stainless or P20) On top of that you would have to add a programming charge of about £60, a tooling up cost of about £60, the billet cost and the CMM charge. I was a machinist and mechanic by trade. I still have a lathe, a vertical mill, a shaper and a T&CG in my workshop here. So, what's P20? Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 5, 2018 Report Share Posted January 5, 2018 P20 is a tough steel that machines to a good finish and is hardwearing. The machine shop I am familiar with use it for injection moulding dies. Its advantage over other tool steels is that it does not have to be heat treated after machining. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted January 5, 2018 Report Share Posted January 5, 2018 It’s also tough but not hard so won’t crack or snap. will rust so needs coating - paint / plating etc Quote Link to comment Share on other sites More sharing options...
thai-ty Posted January 6, 2018 Report Share Posted January 6, 2018 Never heard of it. Sounds like an Araldite brand... I'm more of an EN1, EN1A, EN8, EN16 type of bloke. 1 Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 13, 2018 Report Share Posted January 13, 2018 No way am I suggesting making a case from P20 (it would be totally unsuitable), I just mentioned it because it has similar machining properties (in some ways) and costs to a tough grade of aluminium billet that would be suitable for a case. From a strength point of view (without looking up exact values) P20 is similar to EN24T except it is much easier to get a good finish when machining than it is with the higher EN number steels. I was boring some bright drawn steel a few days ago, what a pile of s--t, variable hardness and a finish like a bear's a--e as they say. Quote Link to comment Share on other sites More sharing options...
thai-ty Posted January 14, 2018 Report Share Posted January 14, 2018 On 1/9/2018 at 8:34 AM, oni nou said: An Enfield man eh ...................Royal? I like anything old. Brit, HD, Guzzi, older Ducati's, air head BMW's, anything that was designed on a drawing board with a sharp pencil and machined on manual machines with jigs and fixtures. So, no CAD, CAM, CNC bollox. Or in other words anything modern. I have yet to own a water cooled bike. I've owned 2 FI Guzzi's, everything else in 41 years of riding and owning motorcycles has been carb'd. Trials bikes - bit of a newbie; Montesa Cota and my ty Monos. Would'nt mind a late Bultaco... Quote Link to comment Share on other sites More sharing options...
