danbillam Posted January 1, 2018 Report Share Posted January 1, 2018 Anyone run the bosi mudguard kit on there evo? Is it more flexible and less brakeable than the original glass one? Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 2, 2018 Report Share Posted January 2, 2018 You do not need a kit. The right gear with proper clutch control will do the job. Sometimes they do crack clean like that. You could just zip tie the fender back on. I have installed these so called kits. Not on my Beta. Taking a picture of the air box after you just washed the bike is pretty lame. You might look up Scottish Six Day bike prep for Beta. 1 Quote Link to comment Share on other sites More sharing options...
canada280i Posted January 2, 2018 Report Share Posted January 2, 2018 Looks like he just pulled the filter out and took the picture of the water that had soaked through it from all the mud that got thrown up under the fender. If the kit is cheaper than a new fender I would just buy it, I heard they were definitely mor3 flexible than beta originals. 1 Quote Link to comment Share on other sites More sharing options...
danbillam Posted January 2, 2018 Author Report Share Posted January 2, 2018 That was with one of those clear plastic sheets covering the airbox aswell as the extended mud flap up the back of the air box. I had repaired it as it was only split on one side so kept using it until broke on both sides. That wasn’t from flipping the bike unfortunately though same as when it first cracked it was from the bike landing on its side. The only way to progress is by going for harder stuff and inevitably you do come off. Quote Link to comment Share on other sites More sharing options...
pjw123 Posted January 2, 2018 Report Share Posted January 2, 2018 Gents, Beta mudguards are somewhat "femmer", & expensive to boot. Not a great deal you can do on the breakage front apart from avoiding unplanned dismounts. Some folks have been known to use 6mm black plastic car number plate bolts, or smaller sizes from Electrical suppliers, which are fine for normal use, but sacrificed in a crash & so allow the mudguard to come off without serious damage, & then be re fitted. On the crud front, remember to seal up the hole where the wiring loom went with silicon & purchase an aftermarket mudflap. There is a talented engineer in North Yorks called mr J Austermuhle who has come up with the best one I've seen. Bosi Beta front is a good idea, as it looks to be far more robust & is used with an with alloy mount which also acts as a fork brace, We live in the faint hope that other manufacturers might take a leaf out of the Montesa book & supply a pair of mudguards at a sensible cost . They also sell high wear plastic parts for sensible money, which is amply demonstrated by the fair number of smart old Monts still going strong. Quote Link to comment Share on other sites More sharing options...
danbillam Posted January 2, 2018 Author Report Share Posted January 2, 2018 On 1/2/2018 at 11:08 AM, pjw123 said: Gents, Beta mudguards are somewhat "femmer", & expensive to boot. Not a great deal you can do on the breakage front apart from avoiding unplanned dismounts. Some folks have been known to use 6mm black plastic car number plate bolts, or smaller sizes from Electrical suppliers, which are fine for normal use, but sacrificed in a crash & so allow the mudguard to come off without serious damage, & then be re fitted. On the crud front, remember to seal up the hole where the wiring loom went with silicon & purchase an aftermarket mudflap. There is a talented engineer in North Yorks called mr J Austermuhle who has come up with the best one I've seen. Bosi Beta front is a good idea, as it looks to be far more robust & is used with an with alloy mount which also acts as a fork brace, We live in the faint hope that other manufacturers might take a leaf out of the Montesa book & supply a pair of mudguards at a sensible cost . They also sell high wear plastic parts for sensible money, which is amply demonstrated by the fair number of smart old Monts still going strong. Expand I’m going to trim the hooked bit that loops under the airbox so it can flex upwards but also cover the gap. I covered the light hole before with a neat piece of plastic so I’ll do the same on This one and also pop some plastic bolts in. Do you use a plastic bolt on the airbox cover aswell or just the 2 side ones? Quote Link to comment Share on other sites More sharing options...
huski Posted January 2, 2018 Report Share Posted January 2, 2018 Motors not going to last long trying to breathe in all that c--p.Was that after a muddier than usual event?Looks like the mudguard broke behind the air box so it should still seal,or am I wrong? Quote Link to comment Share on other sites More sharing options...
danbillam Posted January 2, 2018 Author Report Share Posted January 2, 2018 On 1/2/2018 at 3:42 PM, huski said: Motors not going to last long trying to breathe in all that c--p.Was that after a muddier than usual event?Looks like the mudguard broke behind the air box so it should still seal,or am I wrong? Expand No mate it broke just up to the airbox cover so was exposed about 2 inches at the back of the airbox. Usual conditions round here lol Quote Link to comment Share on other sites More sharing options...
huski Posted January 2, 2018 Report Share Posted January 2, 2018 How about putting it back on with a hinge Quote Link to comment Share on other sites More sharing options...
danbillam Posted January 2, 2018 Author Report Share Posted January 2, 2018 On 1/2/2018 at 6:28 PM, huski said: How about putting it back on with a hinge Expand It didn’t break clean across mate made quite a mess I’ll take a picture tomorrow Quote Link to comment Share on other sites More sharing options...
ridgrunr Posted January 5, 2018 Report Share Posted January 5, 2018 I put a hinge in mine before I broke it. Works great and has popped off twice only breaking two zip ties. Replaced the zip ties and I was in business again. I have bought a Bosi fender mod but have not put it on yet as it doesn't have any of the striping to match and my hinged fender works fine in a fall, and regardless of what everyone says, if you ride, sooner or later everyone falls. If you scroll down on the link here, you can see pics of how I did mine. 2 Quote Link to comment Share on other sites More sharing options...
westygas270 Posted January 10, 2018 Report Share Posted January 10, 2018 I have bossi mudguards on and are spot on good bit of kit Quote Link to comment Share on other sites More sharing options...
