chappo Posted January 15, 2018 Report Share Posted January 15, 2018 Sorry if I'm duplicating a thread, I have searched first, I was sure I'd found an entry where someone had converted the measured value into a quantity per leg. Well I couldn't find it so can anyone help with the per leg quantity of fork oil. Never feel as sure I've got it right with the measurement as I do with a quantity value. Quote Link to comment Share on other sites More sharing options...
thall1 Posted January 15, 2018 Report Share Posted January 15, 2018 The manuals are online.. Go to beta USA website.. My 2013 4t says 70mm and 130mm.... I spoke to beta uk and they said to reduce air gap to 60/120.... Quote Link to comment Share on other sites More sharing options...
chappo Posted January 15, 2018 Author Report Share Posted January 15, 2018 (edited) Thanks thall1, I've seen the UK manual but the oil value is in a mm measurement , I was after a fluid value i.e. How many cc or ml per leg. Or do you mean millilitres not mm ?? Edited January 15, 2018 by chappo Quote Link to comment Share on other sites More sharing options...
thall1 Posted January 15, 2018 Report Share Posted January 15, 2018 sorry mis-read your post.... I gave you MM. In the past I've found this to be more accurate than a volume... There is a volume given in the fluid table at the front of the manual (370ml?) but this doesn't seem to equate to the measurement. It's easy to measure using a 6" rule...just make sure the stantions are compressed as per the manual and also pump them gently to expel the air.... 1 Quote Link to comment Share on other sites More sharing options...
Davidtwinshock Posted January 15, 2018 Report Share Posted January 15, 2018 From what I’ve found out it’s 370 in the (right) rebound side & 350 in the (left,spring side) forks 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 16, 2018 Report Share Posted January 16, 2018 Fork oil is done by level. If done by quantity, you could be doing it a few more times. Quote Link to comment Share on other sites More sharing options...
carlos Posted January 16, 2018 Report Share Posted January 16, 2018 What weight oil do you guy's use on the 2016 models? Quote Link to comment Share on other sites More sharing options...
chappo Posted January 16, 2018 Author Report Share Posted January 16, 2018 Hi Carlos, not sure if mines ever been changed so assuming its original factory fill. But I do find the forks to be soft for my tender 17.5 stone frame, so i'm going to try 10w, thinking the original was probably 5w. If its no better, probably going to go for the stronger spring option. Quote Link to comment Share on other sites More sharing options...
markbxr400 Posted January 19, 2018 Report Share Posted January 19, 2018 On 1/15/2018 at 11:23 PM, carlos said: What weight oil do you guy's use on the 2016 models? From the 2016 EVO 4T Manual: FORK OIL SHELL TELLUS S2 V32 - SAE 6.1 Quote Link to comment Share on other sites More sharing options...
carlos Posted January 19, 2018 Report Share Posted January 19, 2018 6 wt, that's what i thought, Maxima sells a 7 wt oil, mixed it 50/50 with 5 wt. Couldn't get my plastic sleeve out of the tube on the spring side, so just put in the same amount that came out. Quote Link to comment Share on other sites More sharing options...
