mickrayner Posted January 25, 2018 Report Share Posted January 25, 2018 Just got back into trials and picked up a tidy 06 Rev3 270 whick looks to have had an easy life. Im planning on a strip and reassembly replacing fluids, bushes, bearings and seals where needed. Stickers are ok but will replace them during the rebuild. Other than cleaning the stator housing and sealing the cable rubber are there any other top tips to do to improve things? Cheers ? Quote Link to comment Share on other sites More sharing options...
bilks Posted January 25, 2018 Report Share Posted January 25, 2018 Check your water pump housing 1 Quote Link to comment Share on other sites More sharing options...
mickrayner Posted January 25, 2018 Author Report Share Posted January 25, 2018 1 minute ago, bilks said: Check your water pump housing Good plan..I had the oil water mix problem on my old Techno years ago. Coolant and oil are clean and no sign of emulsion. Quote Link to comment Share on other sites More sharing options...
pjw123 Posted January 26, 2018 Report Share Posted January 26, 2018 Water pump case is magnesium & is a guaranteed banker for rot for a bike that age. Last one I bought cost about £90. You might get lucky & be able to repair using Belzona 1111 or similar. Offshore industry uses Belzona regularly to repair pipework on seawater systems. Have you thought about using waterless coolant. Not cheap, but neither are magnesium cases. Quote Link to comment Share on other sites More sharing options...
neils on wheels Posted January 27, 2018 Report Share Posted January 27, 2018 On 26/01/2018 at 11:31 AM, pjw123 said: Water pump case is magnesium & is a guaranteed banker for rot for a bike that age. Last one I bought cost about £90. You might get lucky & be able to repair using Belzona 1111 or similar. Offshore industry uses Belzona regularly to repair pipework on seawater systems. Have you thought about using waterless coolant. Not cheap, but neither are magnesium cases. The replacement housings that you can buy are aluminium. 1 Quote Link to comment Share on other sites More sharing options...
mickrayner Posted January 27, 2018 Author Report Share Posted January 27, 2018 Started work today doing the few bits I know need attention, got my first trial in a long time on the 4th feb so that will showup any more issues. I need to sort the carb to stop the common leaking issue, info on TC was helpful. Quote Link to comment Share on other sites More sharing options...
