potto Posted January 26, 2018 Report Share Posted January 26, 2018 Know the correct mix but need to get the least engine wear and hopefully reasonable amounts of smoke out the back lol,have picked non synthetic oil because oil hopefully has moved on since the late 70's ,really not a fan of synthetic oil so need an answer from folks that have been running the "right" mixture for a while,was thinking 1:30...comments please. As an aside it have exhaust off and not a mark on the piston,and same on the inlet side,want to keep it that way. Cheers Dean. Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 26, 2018 Report Share Posted January 26, 2018 I run Maxima super M in my 348 at 50 to 1. It really depends on which oil you run. You cannot go wrong with Yamalube R at 32 to 1. Quote Link to comment Share on other sites More sharing options...
turbofurball Posted January 26, 2018 Report Share Posted January 26, 2018 Well, I was chucking the same 50:1 synthetic in the Cota as I use in the TY, but someone in the know said it might be an idea to up that a little Short answer, it appears to have been ok on 50:1 synthetic so far! Quote Link to comment Share on other sites More sharing options...
alberto Posted January 27, 2018 Report Share Posted January 27, 2018 On 1/26/2018 at 2:53 AM, potto said: Know the correct mix but need to get the least engine wear and hopefully reasonable amounts of smoke out the back lol,have picked non synthetic oil because oil hopefully has moved on since the late 70's ,really not a fan of synthetic oil so need an answer from folks that have been running the "right" mixture for a while,was thinking 1:30...comments please. As an aside it have exhaust off and not a mark on the piston,and same on the inlet side,want to keep it that way. Cheers Dean. Expand I ride my old Fantics at 80:1 in trial classic competition with sint oil, sure 50:1 with sint oil is ready for a motocross bike, if you ride your bike for trial (always low rpm) you don't need a lot of oil in mix, if you ride your engine quite fast (enduro style) you need more oil more oil mean more deposit on ring (sometime blocked) exaust and silencer so i think it's very important know how you ride your engine which type and brand of oil you can find in your country ? 1 Quote Link to comment Share on other sites More sharing options...
potto Posted January 27, 2018 Author Report Share Posted January 27, 2018 On 1/27/2018 at 8:29 AM, alberto said: I ride my old Fantics at 80:1 in trial classic competition with sint oil, sure 50:1 with sint oil is ready for a motocross bike, if you ride your bike for trial (always low rpm) you don't need a lot of oil in mix, if you ride your engine quite fast (enduro style) you need more oil more oil mean more deposit on ring (sometime blocked) exaust and silencer so i think it's very important know how you ride your engine which type and brand of oil you can find in your country ? Expand Thanks,oil I have is Spectro 2T which I was sold as a mineral oil,most of my riding will be slow trail riding as I'am old and a bit out of practice riding. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 27, 2018 Report Share Posted January 27, 2018 On 1/27/2018 at 8:29 AM, alberto said: more oil mean more deposit on ring (sometime blocked) exaust and silencer so i think it's very important know how you ride your engine which type and brand of oil you can find in your country ? Expand Please can we have an end to this myth being circulated. A correctly tuned engine on good quality oil and fuel does not suffer from these problems even at 25:1 Quote Link to comment Share on other sites More sharing options...
potto Posted January 27, 2018 Author Report Share Posted January 27, 2018 On 1/27/2018 at 9:36 PM, dadof2 said: Please can we have an end to this myth being circulated. A correctly tuned engine on good quality oil and fuel does not suffer from these problems even at 25:1 Expand Thanks heaps ,really thought I would stick to factory mix but putting " feelers " out for actual experience with this bike....have owned 2 YZ125's and Bultaco 175 not to mention one premix sprint ko-cart so failures left right and centre with people playing with mixture. Remember seeing early piston/ring wear on the YZ's and totally seizure on the karts @ the end of the main straight throttle off ,mine never did...right mixture and tuning. Cheers Dean. Quote Link to comment Share on other sites More sharing options...
potto Posted January 28, 2018 Author Report Share Posted January 28, 2018 On 1/28/2018 at 4:49 AM, oni nou said: Put plenty of oil in, the more you put in the better[ More oil = more lubrication]..make sure its mineral oil if you can get it or if not a semi synthetic oil... old bikes don't like modern oils they are old and don't like new fangled stuff. Expand Cheers man,agree totally ,my base knowledge is from real experience remembering my budget for racing bikes and karts in those days was rather limited,I needed stuff to last or was out of the game. I guess if folks have the money they can run what they like but I will put my money on the right mix,thanks to all that have replied,cheers. Over and out ,Dean . Quote Link to comment Share on other sites More sharing options...
dadof2 Posted January 29, 2018 Report Share Posted January 29, 2018 (edited) I would not go as far as looking for mineral oil but I would stick to original mix ratios which would be 25:1 or 32:1 A good oil at a good price for air cooled engines is oregon 2t chain saw oil. Modern fully synthetics intended for liquid cooled engines are low viscosity and rey on a high strength thin film of oil which is not ideally suited to the larger piston to bore clearances in air cooled engines which suit a more viscous oil. I think both Millers and Silkolene make classic air cooled 2T oils. Edited January 29, 2018 by dadof2 Quote Link to comment Share on other sites More sharing options...
