FanticRescue Posted January 29, 2018 Report Share Posted January 29, 2018 (edited) Hi there, can anyone give me a base line jetting for a Fantic 307 at sea level? Full story: I've just gotten my first trials bike, a Fantic 307. It starts but it runs very irregularly, won't idle properly and finally bogs down. Compression gets up to 11 bar in 304 kicks, so that seems solid. Reed valves and intake boots look OK. I've changed the spark plug (the old one was at 0.4mm gap..?), the air filter and the air box cover rubbers. Carb and jets looked clean enough, but it's time to have a second look at the carb. I suspect the float level is all over the place. The jetting seems weird as well, so I'd like to restore everything to stock. Edited January 29, 2018 by FanticRescue Quote Link to comment Share on other sites More sharing options...
breagh Posted January 29, 2018 Report Share Posted January 29, 2018 Hi there this brings back memories but not good ones, I had a 307 new and never got it to run right fiddled with carb settings forever packed in first day of the six days as it just ran terrible. Never got it sorted . If I had one now I would get an OKO and try it I've one on and old Fantic Section runs fine. Sorry I'm little help sure there's others on here who've got them sorted, Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 30, 2018 Report Share Posted January 30, 2018 Do a proper carb clean before chasing anything else. Suppose you have a Del Orto. Make sure the choke circuit is clear that is in the bottom of the float bowl and of course the pilot too. 1 Quote Link to comment Share on other sites More sharing options...
slip_kid Posted January 30, 2018 Report Share Posted January 30, 2018 If you have readily available supply (no supply issue) carburetor parts, that would suggest parts are a reasonable cost. You might replace the needle and seat for the float. Why not if they are cheap? On again, off again "won't idle properly and finally bogs down" sounds like money well spent on those two parts. If you own a number of bikes, have extra money etc, consider investing in an ultra sonic cleaner. Once you learn how to use it, and the many uses it has, you'll wonder why you never bought one before. On the TLR carburetor bodies alone it cleans them wonderfully well. Just be careful with some solvents and the heat the ultra sonic cleaners will/ can produce! Good luck! Quote Link to comment Share on other sites More sharing options...
FanticRescue Posted February 2, 2018 Author Report Share Posted February 2, 2018 (edited) Thanks for the advice guys. Rob from Eurocarb provided me with these data: We have 2 listings for the 307:- Trial 307 89/90 PHBH26CS 60 Slide 9477.74 X74 Needle 13270.274EG Atomiser/Needle jet 6413.135 Main jet 12530.36 Idle jet 7746.70 Choke/starter jet 8649.270 Float valve 9010.2 6.5Gr floats Trial 307 89 -French market PHBH26CS 60 Slide 9477.61 X61 Needle 13270.274EG Atomiser/Needle jet 6413.135 Main jet 12530.38 Idle jet 7746.70 Choke/starter jet 8649.270 Float valve I will take the carb apart and have a more thorough look. Edited February 2, 2018 by FanticRescue Quote Link to comment Share on other sites More sharing options...
FanticRescue Posted February 12, 2018 Author Report Share Posted February 12, 2018 Guys, I'm pretty sure the carb is sorted. Didn't use any new parts, because I'm cheap and it looked pretty good to start with. Jets are clean, float works. ....but the Fantic still won't run reliably. Really looks like an ignition problem now. It starts when cold, runs OK with the occassional hiccup and then suddenly dies after riding for 5 minutes never to start up again. Obviously at that point you keep kicking like a maniac, drown the thing, kick some more, slide off the tired kick starter, sprain your ankle and utter very, very naughty words. I can feel the gods of Italian motorcycles mocking me. Ha! Joke's on them, I've had a Cagiva with electronic injection and numerous other crappy 80s and 90s motorcycles. And these days I have access to a proper motorcycle workshop with lifts and heating and tools and compressed air........so bring it on. Ignition troubleshooting mode.....ENGAGE!! When I spin up the crank with an electric drill the spark looks weak and irregular, like it skips every 8 rotations or so. When I hook up the multimeter to the leads from the stator these are the values. Mind you, resistance is measured statically and voltage is measured while running the crank with an electric drill. Brown - Red 5.0v (ac) and 111 ohm Brown - White 5.6v (ac) and 0.6 ohm Brown - Green 49.5v (ac) and 372 ohm Lacking a proper manual...am I doing this correctly? Do these values look familiar? I've tried pulling the flywheel to figure out what is what but it's some exotic size I don't have lying around like 32. Quote Link to comment Share on other sites More sharing options...
FanticRescue Posted March 18, 2018 Author Report Share Posted March 18, 2018 (edited) So, next part of the Fantic Fiasco. By now I've had the ignition source coil on the stator rebuilt by a local coil rebuilding guru. Two other companies wouldn't touch it. Guess putting on 3500 windings of 0.1mm copper wire is a specialty job, who would have thought. That fixed the weak and irregular spark. Starts on first kick and keeps running! Victory! I've also replaced the front brake pump with an AJP as I was unable to source a rebuild kit for the stock 10mm Brembo. Welded the holes in the header pipe, cleaned the brakes front and rear... So yesterday and today I finally took the Fantic out to ride......and it's still not running properly. Throttle cable tends to get stuck and every now and then it loses power, bogs down and dies. Back to the work shop. I might just rebuild the carb properly now, at the very least replace seals and float assembly and replace both inlet rubbers. Funny thing is that it still runs with the mixture screw all turned in, that can't be right. Fuel tap is suspect as well. Getting there. Edited March 18, 2018 by FanticRescue Quote Link to comment Share on other sites More sharing options...
cangy1000 Posted March 25, 2018 Report Share Posted March 25, 2018 https://www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/complete-carburettors-dellorto-motorcycle-carburettors-parts/phbh-26-to-30mm/r4168-phbh-26cs-gas-gas/ Surprisingly cheep if its the same as yours...better than messing around with old carbs. 1 Quote Link to comment Share on other sites More sharing options...
Olsen Posted July 20, 2020 Report Share Posted July 20, 2020 Well, a few years later... I have the chance to buy a reasonably nice 307 from a coworker. He says that it runs well, except that when it warms up, and he applies throttle, it hesitates, and then goes. This sounds a bit like FanticRescue's issue. Did this ever get resolved? Any recommendations, like 'Don't buy this bike, you fool!", or "Yeah, just do THIS, and it will work fine." I can get this for reasonable $$$, and I am on a very limited budget, so if I buy a disaster, I won't be able to afford to fix it, perhaps. Thank you for any advice! Quote Link to comment Share on other sites More sharing options...
slip_kid Posted July 21, 2020 Report Share Posted July 21, 2020 2 hours ago, Olsen said: I can get this for reasonable $$$ How much is reasonable? Quote Link to comment Share on other sites More sharing options...
FanticRescue Posted July 29, 2020 Author Report Share Posted July 29, 2020 On 7/21/2020 at 12:24 AM, Olsen said: Well, a few years later... I have the chance to buy a reasonably nice 307 from a coworker. He says that it runs well, except that when it warms up, and he applies throttle, it hesitates, and then goes. This sounds a bit like FanticRescue's issue. Did this ever get resolved? Any recommendations, like 'Don't buy this bike, you fool!", or "Yeah, just do THIS, and it will work fine." I can get this for reasonable $$$, and I am on a very limited budget, so if I buy a disaster, I won't be able to afford to fix it, perhaps. Thank you for any advice! Hey Olsen, I'm with team 'Don't buy this bike, you fool!' I'm afraid. After sorting the carb and the ignition my 307 still wouldn't run reliably. The next step would have been to pull the engine apart, but by that time work-related stress was eating me alive so I got rid of it. Mine was old and worn down and it would have needed new tires and some other parts. It quickly adds up. I haven't been able to afford another trials bike since then, but I would save up and get something newer for sure. If you want to proceed with the 307, go over the carb and check for a healthy spark. If you run into problems, ask here and I will see what I can dig out of my memory. Quote Link to comment Share on other sites More sharing options...
farfromgood Posted August 4, 2020 Report Share Posted August 4, 2020 Hi All I have just bought a fantic 307 and im looking for a bit of help the bike has good compression and starts in a couple of kicks (would be less kicks if the kick start wasnt all backward) it runs fine while riding the problem is it has a real bad hanging idle and the air screw or what ever it is on the dellorto phbh 26 carb doesnt seem to do anything i have pulled the carby out and cleaned it with compressed air and it seems to be ok any suggestions on what to look for or should i just buy a mikuni or keihin carb Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 4, 2020 Report Share Posted August 4, 2020 Did you actually remove the slow jet? Quote Link to comment Share on other sites More sharing options...
farfromgood Posted August 4, 2020 Report Share Posted August 4, 2020 I took the pilot jet out yes Quote Link to comment Share on other sites More sharing options...
