motopelli Posted February 3, 2018 Report Share Posted February 3, 2018 My 350 Jumbo had a 15 tooth countershaft sprocket which looks gigantic. Does anyone know what the original set up was for front and rear? Also are there supposed to be spacers between the front sprocket guard and the engine cases? Thanks Quote Link to comment Share on other sites More sharing options...
fourex Posted February 5, 2018 Report Share Posted February 5, 2018 (edited) 13T /38T. I don't think there are any spacers if you run the 13T front sprocket as it basically envelopes the sprocket to prevent a derailment destroying the cases, mine doesn't have one so can't be 100% sure. I'll attach the parts manuals. 350TLSWM1983.pdf 350TLSWM1983-2.pdf PS: Some of those part numbers are all messed up, front sprocket should be # 29, not #27. You'll see what I mean. Edited February 5, 2018 by fourex PS added. Quote Link to comment Share on other sites More sharing options...
motopelli Posted February 7, 2018 Author Report Share Posted February 7, 2018 Thanks Fourex. Thirteen tooth on order! Quote Link to comment Share on other sites More sharing options...
