VAUXHALL Vivaro 2015 New shape
westyfield7
Have you tried using the dash mounted button  to rule out the key fob
It doesn't sound like key fob batterys
I have had other minor issues but its the first time ive heard of your fault
im assuming the warranty has expired ,you could try asking the dealer if its a known fault
3 hours ago, westyfield7 said:
Has anyone had trouble with the rear door central locking? The rear door locks ok but then won't unlock on the button..  it's then necessary to release it from the inside. Not easy if bikes in the way. Is it a common problem? Is there a fix?
I don't know this vehicle but know central locking....it can be a pain,as the solenoids get older they get weaker,it makes no difference if they air driven or electrical types,another issue is the linkage rods can get sticky with dust and dirt,pop the cover panel and make sure the are well lubricated.
If the solenoids are electric make sure the power plug is clean and well connected,on a vacuum solenoid check to make sure the air line is on properly.
Lastly try a new battery in the remote...you never know,good luck.
  • 2 weeks later...
