scifi Posted February 16, 2018 Report Share Posted February 16, 2018 My Beta 300 has a very abrupt clutch, which I made a temporary cure by taking out two of the 6 springs. This however makes the clutch slip in top gear at maximum throttle. So I have made some stepped clutch washers, which just slightly reduce the clutch pressure, which I am going to fit soon. Maybe you need less spring force as well, so pack a small washer under some of your spring bolts, but not so many that the clutch slips in top gear. . Quote Link to comment Share on other sites More sharing options...
