Rev3 brake pedal fit Evo?
mcman56
Let me start by acknowledging the fact that I haven't tried to exchange them, but I do have a 2007 Rev 3 and a 2014 Evo in the garage. My guess is that it will not work. The rear leg of the Rev 3 pedal is longer, which accommodates the location of the master cylinder. The master cylinder on the Evo is positioned further back on the frame and the rear leg of the pedal is shorter. If you installed a Rev 3 pedal on an Evo, I'm not sure the push rod for the master cylinder will line up.
