Fishlp Posted February 18, 2018 Report Share Posted February 18, 2018 Got a leaky clutch arm is there any thing I have to look out for, looks like it can be changed from bottom of motor? Any comments would be greatly appreciated, thanks david Quote Link to comment Share on other sites More sharing options...
tony27 Posted February 19, 2018 Report Share Posted February 19, 2018 Ideally you'll need to remove the clutch pressure plate so that the pushrod doesn't stop you getting the cam back in, the cam is fatter at the end than the middle Undo & remove the adjuster nut & screw before trying to pull the cam out Quote Link to comment Share on other sites More sharing options...
Fishlp Posted February 19, 2018 Author Report Share Posted February 19, 2018 Thanks tony Quote Link to comment Share on other sites More sharing options...
