ossatr250i Posted February 19, 2018 Report Share Posted February 19, 2018 Need help with bleeding the rear brakes, i’ve been pumping and bleeding at the caliper for 30 minutes now, still no peddle, refilled the reservoir 3 times...no progress. I even tried to raising the front of the bike, pushing fluid, pulling fluid, still no progress. thanks Phil. Quote Link to comment Share on other sites More sharing options...
gasserguy Posted February 19, 2018 Report Share Posted February 19, 2018 Syringe and reverse bleed. A couple of quid on ebay..... Tons of videos on You tube...... Quote Link to comment Share on other sites More sharing options...
kurtas Posted February 20, 2018 Report Share Posted February 20, 2018 Take the reservoir off the bike and use a small screwdriver or the like to push the piston in as far as possible. Then crack the banjo at the reservoir to bleed the line. It is important that you then get just the right angle on the hose when you are finished bleeding from the banjo. If its too low the swingarm will raise up and knock the banjo loose and if it is too high the exhaust will overcook the porridge. Other thing to check is that the master cylinders piston seal isn't damaged, if above doesn't help you. Quote Link to comment Share on other sites More sharing options...
ossatr250i Posted February 20, 2018 Author Report Share Posted February 20, 2018 Thank you for the help. Kurtas, good tip on the brake hose, I noticed mine had previously hit the swing arm...so I angled it up about 1/4” from the silencer. Phil. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted February 21, 2018 Report Share Posted February 21, 2018 Make absolutely certain the brake rod has clearance to the master cylinder piston. AND that the piston is coming all the way back down. Mine had that haywire ‘sideways lid’ on the master. So I need to either bleed from the back and open the screw- or use a syringe to bleed from the front. mark Quote Link to comment Share on other sites More sharing options...
