misterroy Posted March 1, 2018 Report Share Posted March 1, 2018 Sherco 290 My cylinder is off to get replated. The conrod kit at £210 looks pricey if the conrod is ok. There is play at the big end, how would I know if the conrod is OK to reuse? thanks Quote Link to comment Share on other sites More sharing options...
misterroy Posted March 1, 2018 Author Report Share Posted March 1, 2018 even if I buy a new bearing and the pin? Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted March 1, 2018 Report Share Posted March 1, 2018 Wot he said. While it's stripped down that far do a good job and you shouldn't need to repeat again for years. Quote Link to comment Share on other sites More sharing options...
mrtmartinp Posted March 1, 2018 Report Share Posted March 1, 2018 Seems the sensible route to buy the rod kit despite the cost. Many moons ago I had a Suzuki AC50, rare thing even then. That needed a big end change, and because the bearing was obsolete the company who rebuilt the crank bored out the rod to accept a slightly larger OD bearing. I would only consider this if parts were not available, and the value/risk was low. TBH never felt 100% happy about it, but had no choice. So vote for me is the rod kit route Quote Link to comment Share on other sites More sharing options...
mrtmartinp Posted March 1, 2018 Report Share Posted March 1, 2018 Cos I've got too much time on my hands tonight, found this, might save a few quid. Have never used the company and not 100% sure it's the right one, but maybe worth a look. Using XE.com this rod kits is £164 plus del. Looks like some kind of dealer clearance of Sherco parts? https://shercodiscountparts.com/collections/sherco-trials/products/conrod-kit-2-5-2-9-r021 Quote Link to comment Share on other sites More sharing options...
peterb Posted March 1, 2018 Report Share Posted March 1, 2018 What oni nou said, you need the con-rod, pin and bearing. Any wear on the big end usually affects the con-rod bearing surface, the pin and the rollers. Either your bike is really old, has had a lack of oil or has been drowned in water which has settled for a while for the big end to wear, not the norm on later day bikes for big ends wearing out. Bye, Peter B. Quote Link to comment Share on other sites More sharing options...
copemech Posted March 1, 2018 Report Share Posted March 1, 2018 On 3/1/2018 at 6:12 PM, misterroy said: Sherco 290 My cylinder is off to get replated. The conrod kit at £210 looks pricey if the conrod is ok. There is play at the big end, how would I know if the conrod is OK to reuse? thanks Expand What sort of play? They all move side to side, you know. Vertical play can be more difficult to check. Quote Link to comment Share on other sites More sharing options...
SquamishDroc Posted March 2, 2018 Report Share Posted March 2, 2018 On 3/1/2018 at 9:32 PM, mrtmartinp said: Cos I've got too much time on my hands tonight, found this, might save a few quid. Have never used the company and not 100% sure it's the right one, but maybe worth a look. Using XE.com this rod kits is £164 plus del. Looks like some kind of dealer clearance of Sherco parts? https://shercodiscountparts.com/collections/sherco-trials/products/conrod-kit-2-5-2-9-r021 Expand I just bought some parts for my bike from that site. Saved over $200 on the stator for my bike as opposed to getting it from my local dealer. That company is in Canada so shipping might be higher than what you might expect. Quote Link to comment Share on other sites More sharing options...
misterroy Posted March 2, 2018 Author Report Share Posted March 2, 2018 the play is somewhere around 1mm up and down. will buy the kit. Quote Link to comment Share on other sites More sharing options...
suzuki250 Posted March 2, 2018 Report Share Posted March 2, 2018 On 3/2/2018 at 7:00 AM, misterroy said: the play is somewhere around 1mm up and down. will buy the kit. Expand then its scrap, With 1mm play up & down it would be knocking, and not far off punching a hole in the crank cases! 2 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 2, 2018 Report Share Posted March 2, 2018 I was thinking piston/head contact☺ Quote Link to comment Share on other sites More sharing options...
misterroy Posted March 2, 2018 Author Report Share Posted March 2, 2018 I don't think there was contact with the head, it looks fine. The piston is scored and the cylinder has a wee mark.` Quote Link to comment Share on other sites More sharing options...
misterroy Posted March 7, 2018 Author Report Share Posted March 7, 2018 Where in the UK will rebuild my crankshaft? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted March 7, 2018 Report Share Posted March 7, 2018 On 3/2/2018 at 5:31 PM, oni nou said: It may have been a passing dog or a tom cat spraying....they're a pain in the ass. Expand You jest but, decades ago, a pal put the bottom half of his Yamaha racing motor below the bed for winter storage. The evident rust come springtime was due to the cat having "used" the crankcase. When he told us this I don't think he realised what it said about the state of his room that he hadn't noticed the smell when it happened. 2 Quote Link to comment Share on other sites More sharing options...
misterroy Posted March 11, 2018 Author Report Share Posted March 11, 2018 Googling may not work for this one, "We dont do Sherco" is the reply from 3 businesses so far. Quote Link to comment Share on other sites More sharing options...
