mink_man Posted March 3, 2018 Report Share Posted March 3, 2018 (edited) I have searched the depths of the internet to find a replacement for this carburettor but I have just about given up on hope in finding one. Please can someone point me in the right direction to a mikuni specialist or advice on a suitable replacement. Its is for a 176.3cc 4 Stroke engine. The numbers on it are : 24506 D561 Thanks in advance. Edited March 3, 2018 by mink_man Quote Link to comment Share on other sites More sharing options...
tony27 Posted March 3, 2018 Report Share Posted March 3, 2018 I would suspect Yamaha DT175 but not sure of exact model. 506 looks like pre80 model numbers Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 3, 2018 Report Share Posted March 3, 2018 That looks like a carby made specifically for a manufacturer for a particular model bike so will not be available new from Mikuni. It would be helpful to share what motor the carby came from. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 3, 2018 Report Share Posted March 3, 2018 41 minutes ago, tony27 said: I would suspect Yamaha DT175 but not sure of exact model. 506 looks like pre80 model numbers Yamaha 506 is YB100 (two stroke) Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 3, 2018 Report Share Posted March 3, 2018 If the existing carby mount attaches to the head with two studs, you might be able to use a (flange-mount) pit-bike carby. It would require a flat isolator and longer studs Quote Link to comment Share on other sites More sharing options...
mink_man Posted March 4, 2018 Author Report Share Posted March 4, 2018 Thanks for the replies so far, its for a HERCHEE Adly 220 Quad 180cc. Ive tried fitting a 28mm MOLKT carb this week but it was a bad idea, even with the jet kit it is just to big for that engine. Quote Link to comment Share on other sites More sharing options...
Bermshot Posted July 18 Report Share Posted July 18 I have those carbs, I was the Tech manager for Adly Moto until they pulled back from the US. It's a 24mm carb, 105 main, 22.5 pilot jet, NJ 1E, Needle 5Ngy72 and a 2.o slide. They are set up for a cable choke but you can buy pull or lever chockes for them on the market. Not sure since Sudco is closing up. Quote Link to comment Share on other sites More sharing options...
