Lefebvre Posted March 6, 2018 Report Share Posted March 6, 2018 Does the clutch drag still be a problem for the 2018? What is the best fix? New carbon plates? Clean the glue? Or has the problem been solved by Beta? Quote Link to comment Share on other sites More sharing options...
dan williams Posted March 7, 2018 Report Share Posted March 7, 2018 Seems to be much better. Quote Link to comment Share on other sites More sharing options...
carlos Posted March 7, 2018 Report Share Posted March 7, 2018 Have yet to take my 2017 Factory 250 clutch a part and do "the fix" yet. Happy with stock. Quote Link to comment Share on other sites More sharing options...
chesticle Posted March 8, 2018 Report Share Posted March 8, 2018 Unfortunately, I think you know the answer... clean the glue from the friction plates and file the burrs off of the tabs on the friction plates. Pour yourself a glass of wine and get filing...it's worth it. Quote Link to comment Share on other sites More sharing options...
dan williams Posted March 8, 2018 Report Share Posted March 8, 2018 (edited) The glue application is much better now which helps the old cold stick but I still plan to polish the tabs on my new clutch once the succession of blizzards stop here. I have to say though the stock clutch on my 2018 300 isn’t bad at all. Edited March 8, 2018 by dan williams Quote Link to comment Share on other sites More sharing options...
Lefebvre Posted May 12, 2018 Author Report Share Posted May 12, 2018 On 08/03/2018 at 12:03 AM, dan williams said: The glue application is much better now which helps the old cold stick but I still plan to polish the tabs on my new clutch once the succession of blizzards stop here. I have to say though the stock clutch on my 2018 300 isn’t bad at all. Hi! Dan Williams and everyone, I will pick up my 2018 Beta Evo 200 next Tuesday in Canada. Dan, I will let you know how it all goes with the washers for the clutch. Would you recommend that I run OEM set up before to appreciate the difference more or just install it right away to make it easier? As I am an old man and beginner in Trial, do you recommend that I install a throttle tamer for a while until I get use to the grip / power of the bike? Thanks a lot Dan for making it easier for me at riding this new Trial adventure and I will keep you inform. Quote Link to comment Share on other sites More sharing options...
dan williams Posted May 12, 2018 Report Share Posted May 12, 2018 Stock is not a bad bike. The newer clutches are a lot better so plunking around on a stock bike for a while is OK. The 200 is such a sweet motor. You won’t even notice much difference between the stock clutch and the spacers immediately anyway. Where it becomes significant is end of an event after three-four hours on the bike that forearm fatigue makes the clutch finger weak. Then the lighter clutch pull helps. Get to know the bike first. Get some hours in and then you’ll know what you want to change to suit yourself. Maybe you’ll love it stock. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted May 12, 2018 Report Share Posted May 12, 2018 By throttle tamer I assume you mean a slow action throttle. The 200 should be so equipped as standard - rideability is, after all, the reason for the existence of the 200. Quote Link to comment Share on other sites More sharing options...
