nzwillie Posted March 11, 2018 Report Share Posted March 11, 2018 hi I just bought a 2006 sy250 I got it has a couple of probs the coil lead is melted on the head ,it has melted the rubber but not thru to the wires I have taped it up for now can I replace the lead or do I have to replace the coil as well ? the top end has a rattle it seems worse when its cold idle ,doesn't seem that bad once warm .I will pull it down and inspect the barrel/piston this week it is a bit hard to start when its cold,cleaned the airbox had a lot of crap in there the filter was filthy , cleaned the carb it had a lot of crap in there mostly in the choke, air screw is only 1/4 turn out ,replaced spark plug ,choke on takes anything up to 20 kicks when cold to start ,,once warm it starts first kick ,once warm leave it for 5 min and will take 3 kicks , I don't no trials bikes at all but the spark is white but the spark seems very small {compared to a dirt bikes spark} I will check all the earths on the bike and sort the melted lead, the exhaust is chocka block with crud I will attempt to burn it out this arvo not sure if that has anything to do with cold starting I'm totally new to trials had a life time on dirt bikes,i had my first day trials riding yesterday on this and its the most fun iv had on a bike in along time any help would be appreciated cheers Quote Link to comment Share on other sites More sharing options...
