Beta techno running backwards
Danieljohn
  On 3/17/2018 at 8:42 AM, 2stroke4stroke said:
I'm not a gambler, never having placed a personal bet in a bookies, so wouldn't be inclined to take a punt on a stator from a breaker.  At least a professionally  sorted one will work, and for a reasonable time.
Expand
Mr Allen is not known for selling duff parts.
These may sound daft, but due to the running backwards, is the flywheel hub fixed to the flywheel, ie riveted. Has the crankshaft half spun in the crankshaft web. Not sure here if the crankshaft is an interference/ splined fit to the crank web or machined as one?
Or was Merlin the magician annoyed at the noise and put a spell on the fiendish machine.??
Expand
My comments were not directed at any particular breaker but how could anyone stripping a bike know if the ignition worked properly once the bike had been running for an hour or so?  Problems often only appear when the motor is fully hot. The breaker is (honestly) gambling as much as the buyer.
Expand
Agree entirely. Except some breakers take apart already running bikes as that’s a more lucrative way to make money!??
Expand
Expand
Expand
agree i,ve known richard since the late seventies and never had or heard of any problems with him .
Hi guys bit of an update I’ve checked cleaned carb, reeds, exhaust I purchased a new coil a new plug, cap and Ht lead woodruff key and timing is ok I’ve now sent my stator and cdi unit to Bradford ignitions in Cornwall they specialise in beta techno electronics and many others but they do list this make and model on Thair website (motoplat) will let you know what they say is wrong with my Elecs they have the equipment and knowledge to bench test these.
  • 1 month later...
Hi guys sorry it’s been a while I’ve had my stator rewound and all my Elecs tested at Bradford ignitions it turned out to be the cdi unit does anyone know where I could source 1 or get this repaired thanks
