sy rear sprocket
bondy
I spoke with Mike Komer while seeing if his shop had a Talon rear sprocket with added teeth from stock.  His recommendation was 40 or 41 being what he rode back when these bikes were current.
Mine at 10:40 seems good so far.  Better low speed control and less abrupt launch.  41 might work, but suspect 42 would have difficulty keeping the front wheel floated as the engine winds up quickly.
You might not easily find a 40t with the countersunk holes.  My recent search only found oem 38t with countersunk holes.  Ultimately, I bought a new old stock and modified it to fit properly.
If you are also installing a new chain, do your homework, as some chains are physically larger than others, and will require attention on the tensioner block and possibly the center exhaust box.
