miner Posted May 4, 2018 Author Report Share Posted May 4, 2018 Squeaking noise identified..... Ignition side cover is loose and flywheel is covered in dirt.... definitely the squeaking noise but don't have the puller.... any other way to get the flywheel off to clean up and check stator? Quote Link to comment Share on other sites More sharing options...
snowball Posted May 4, 2018 Report Share Posted May 4, 2018 nope, I think you need puller ,10 pounds Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 5, 2018 Report Share Posted May 5, 2018 back to the start you pressure washed it THEN started it till bowl was dry? Quote Link to comment Share on other sites More sharing options...
miner Posted May 5, 2018 Author Report Share Posted May 5, 2018 (edited) On 5/5/2018 at 5:13 AM, nigel dabster said: back to the start you pressure washed it THEN started it till bowl was dry? Expand Yes - why? Till the revs started to rise then killed it. Hot enough outside to dry the rest (30++). Edited May 5, 2018 by miner Clarification Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 6, 2018 Report Share Posted May 6, 2018 Oh dear 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 7, 2018 Report Share Posted May 7, 2018 2 things never start a bike after pressure washing never run a bike particularily a 2 t till fuel runs out Quote Link to comment Share on other sites More sharing options...
miner Posted May 13, 2018 Author Report Share Posted May 13, 2018 On 5/7/2018 at 5:50 AM, nigel dabster said: 2 things never start a bike after pressure washing never run a bike particularily a 2 t till fuel runs out Expand What's the issue with starting after pressure washing? Wet filter? Not killed a bike yet.... Quote Link to comment Share on other sites More sharing options...
miner Posted May 13, 2018 Author Report Share Posted May 13, 2018 Found part of the gasket is missing on the 5-o'clock position.... there's the source of the dust ingress.... Quote Link to comment Share on other sites More sharing options...
richt Posted May 13, 2018 Report Share Posted May 13, 2018 The gasket is pretty useless the cover is too flexible to seal between the bolts. I have not got one on mine and its not been a problem. All the Gassers I have bought all had a 3mm hole at the bottom of the cover, Don't know if this is a mod people do or manufactured with one. 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 14, 2018 Report Share Posted May 14, 2018 On 5/13/2018 at 8:52 AM, miner said: What's the issue with starting after pressure washing? Wet filter? Not killed a bike yet.... Expand oh dear, wheres forest gump when you need him. Quote Link to comment Share on other sites More sharing options...
miner Posted May 15, 2018 Author Report Share Posted May 15, 2018 On 5/14/2018 at 11:11 AM, nigel dabster said: oh dear, wheres forest gump when you need him. Expand Answer the point or butt out... not killed a dirt bike in 10yrs but my experience is more with closed airbox road bikes so I may have missed something.... please enlighten me and Forrest will give you one of his chocolates.... Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 16, 2018 Report Share Posted May 16, 2018 On 5/13/2018 at 8:52 AM, miner said: What's the issue with starting after pressure washing? Wet filter? Not killed a bike yet.... Expand ok. In plain english (not american) you cannot be sure where water has got in when you pressure wash. It could get in several places where you dont want it, air filter for example where water borne dirt could enter the engine when started. Water in the electrics around head stock or in the ignition side and so on. Its bad practice and most who know anything about trials mechanics wouldnt choose to do. maybe youve been lucky but i wouldnt spend 6k on a bike and take a chance for an hour of fettling. Im off now. 1 Quote Link to comment Share on other sites More sharing options...
miner Posted May 16, 2018 Author Report Share Posted May 16, 2018 On 5/16/2018 at 5:33 AM, nigel dabster said: ok. In plain english (not american) you cannot be sure where water has got in when you pressure wash. It could get in several places where you dont want it, air filter for example where water borne dirt could enter the engine when started. Water in the electrics around head stock or in the ignition side and so on. Its bad practice and most who know anything about trials mechanics wouldnt choose to do. maybe youve been lucky but i wouldnt spend 6k on a bike and take a chance for an hour of fettling. Im off now. Expand Genuinely thanks for that... I was annoyed more at not getting a straight answer.... once or twice, bit of forum banter, etc... no issues, copped and dished plenty of it out... but one step beyond in the end. It I wanted trolled I'd have posted on The Rev Counter... expected better from a house elf Was a little concerned I'd missed something major and was at risk of taking good care of the rest of it but finished it off but chucking a grenade in at the end. Agree with your points, all makes sense... mostly experienced with Enduro/Road bikes and careful with the pressure washer... not much to cover up the innards of the trials bike though. Not so sure about the american chat though.... I've got some of my best Jockanese in response to that! Quote Link to comment Share on other sites More sharing options...
miner Posted May 16, 2018 Author Report Share Posted May 16, 2018 Anyway.... puller came in the post from GG UK eventually yesterday.... flywheel certainly came off with a pop and when the ball bearing dropped so did my a*** a little... woodruff key still there, as you were! Cleaned it all up, including getting all the crud off the flywheel with some 400 grit paper, squeaking noise gone... noticed a few odd things regarding the ignition which I've posted on the ongoing ignition thread. Need a new gasket, just boxed it up for now. Only the carb and linkage to clean up and it's ready for reassembly, including new exhaust joints. Only set out to change the chain slider.... bike currently in bits. Quote Link to comment Share on other sites More sharing options...
shipdamite Posted May 16, 2018 Report Share Posted May 16, 2018 On 5/16/2018 at 5:33 AM, nigel dabster said: ok. In plain english (not american) you cannot be sure where water has got in when you pressure wash. It could get in several places where you dont want it, air filter for example where water borne dirt could enter the engine when started. Water in the electrics around head stock or in the ignition side and so on. Its bad practice and most who know anything about trials mechanics wouldnt choose to do. maybe youve been lucky but i wouldnt spend 6k on a bike and take a chance for an hour of fettling. Im off now. Expand Rubbish. Jet wash carefully avoiding bearings and electrics. Airbox and exhaust blocked. START bike after washing to ensure it doesnt condensate in the engine. 30 years tried and tested. 1 Quote Link to comment Share on other sites More sharing options...
