Andyb1987 Posted March 27, 2018 Report Share Posted March 27, 2018 What is the standard jetting for the early 315 '97-'99 PHBH 26CS CARB? Only manual I can get is 2002 which has the newer carb Quote Link to comment Share on other sites More sharing options...
naichuff Posted March 27, 2018 Report Share Posted March 27, 2018 I have an old 99 manual and it says for a carb PHBH26CS main jet(standard) 135 Slow jet(standard) B46(upper) 46 ( lower) Needle clip 3rd groove Air screw 1 turn out float 18.5 mm Hope this is a help to you Quote Link to comment Share on other sites More sharing options...
pjw123 Posted March 27, 2018 Report Share Posted March 27, 2018 Speak to the guys at Splat shop. They'll tell you exactly what set up you require. 315 standard Carburation always had room for improvement. 1 Quote Link to comment Share on other sites More sharing options...
Andyb1987 Posted March 27, 2018 Author Report Share Posted March 27, 2018 Thanks 1 hour ago, naichuff said: I have an old 99 manual and it says for a carb PHBH26CS main jet(standard) 135 Slow jet(standard) B46(upper) 46 ( lower) Needle clip 3rd groove Air screw 1 turn out float 18.5 mm Hope this is a help to you Thanks it currently has a 120 main 46 upper 46 lower needle clip is correct yeah thanks big help. Will order a new main straight away Quote Link to comment Share on other sites More sharing options...
