RT260 front caliper
deleriousdave
Broke one of the front brake caliber bolts while taking off the forks for a fluid change. 2016 model, only 13 hours on it, this was the first time the bolt was turned since coming from the factory. I need to take the caliber apart to get the remaining bolt out. The manual suggests replacing the whole unit if any part is damaged so no disassembly info.
Does anyone have some experience taking the caliber apart? Looks straightforward, only a bolt and a screw, but will it go back together?
