benspeed888 Posted December 19, 2005 Report Share Posted December 19, 2005 hi all is the intake manifold for a beamish still available? i noticed a split in mine tonite. if they are no longer available, is there a way of fixing it thanks Ben Quote Link to comment Share on other sites More sharing options...
rob w Posted December 20, 2005 Report Share Posted December 20, 2005 (edited) Hi Ben, WARNING - BLATANT ADVERTISEMENT FOLLOWING If you can't find a NOS or even a good used one to replace yours then I can reproduce one for you. If it is a simle rubber tube then it is relatively easy and cheap. If it has a metal plate bonded in then it gets a lot more expensive, but I can still do it. I would need you to send me the part you have so I can restore it and take a mould from it. My webpage is undergoing a change of provider at the moment so there is not much point looking there, but here are some pics of pieces I have done. Cheers Rob 4.RoBs (Robs Replica and Reproduction Rubber for Old Bikes) Edited December 20, 2005 by Rob W Quote Link to comment Share on other sites More sharing options...
