kingkopity Posted April 9, 2018 Report Share Posted April 9, 2018 Hi all. Thinking of fitting a smaller sprocket to the rear for trail riding. Hoping it will put less stress on the motor while at a semi high constant speed. Any suggestions on which size sprocket to go for?. Many thanks. Quote Link to comment Share on other sites More sharing options...
section swept Posted April 10, 2018 Report Share Posted April 10, 2018 11 hours ago, kingkopity said: Hi all. Thinking of fitting a smaller sprocket to the rear for trail riding. Hoping it will put less stress on the motor while at a semi high constant speed. Any suggestions on which size sprocket to go for?. Many thanks. Smaller sprocket......it might be easier to fit a larger front drive sprocket as you may not need to increase chain length as with a larger rear. Two teeth on the front would probably equal ten off the rear, but with no teeth numbers calls not possible. Quote Link to comment Share on other sites More sharing options...
kingkopity Posted April 23, 2018 Author Report Share Posted April 23, 2018 Thanks for the reply. It's currently using 10 front and 102 rear. The only alternative I can get for the front is actually smaller at 9t. I can get anything up to 99 for the rear. Quote Link to comment Share on other sites More sharing options...
Ahoffman Posted October 17, 2018 Report Share Posted October 17, 2018 I got an 11t (one tooth larger) front sprocket from Oset but they don't have anything smaller for rears. You mentioned that you can get a 99t, where at? Quote Link to comment Share on other sites More sharing options...
