Merch Guy Posted April 9, 2018 Report Share Posted April 9, 2018 I've been working on the Monty trying to get it fit for use again and been frustrated so far at my attempts to fix the clutch so far. I've replaced the slave cylinder with a good replacement, new braided hose, rebuilt the master cylinder and bleed it all. Still when sitting cold and still I can't get the clutch to release !! Help, I'm at my wit's end and ready to give up. Quote Link to comment Share on other sites More sharing options...
rotors7 Posted April 9, 2018 Report Share Posted April 9, 2018 In the past I've fired mine up in first gear, as it's warming up I've kept pulling the clutch in and using the brakes at the same time, it always did the trick. I presume you've got some good dimpled clutch plates in there with some atf oil or whatever's used these days ? Quote Link to comment Share on other sites More sharing options...
Merch Guy Posted April 9, 2018 Author Report Share Posted April 9, 2018 Thanks for the reply. I'll try that before starting to take the clutch out. Got to be worth a try! Quote Link to comment Share on other sites More sharing options...
dan williams Posted April 9, 2018 Report Share Posted April 9, 2018 Take a look at the clutch fix pinned to the top of the Beta forum. It may help. Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 9, 2018 Report Share Posted April 9, 2018 (edited) Is it ok when warm ? If it is, dont worry, just live with it ! Edited April 9, 2018 by b40rt Quote Link to comment Share on other sites More sharing options...
section swept Posted April 10, 2018 Report Share Posted April 10, 2018 Run the engine for a few minutes, kill engine, select first or second and with clutch pulled in rock bike back and forth until you feel the clutch let go. Strip and careful inspection and clean as Oni Nou suggests would be a good idea, get rid of any burrs found on the clutch drum and plates. You say you have replaced the slave cylinder with a good one if this is second hand ensure that there is no corrosion inside the slave cylinder bore, this will shorten slave piston movement. As Oni Nou indicates about the bearing in between the two push rods you may also consider getting one push rod a few mm longer, this may alleviate the issue altogether. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 10, 2018 Report Share Posted April 10, 2018 does the 315 have pushrods? Quote Link to comment Share on other sites More sharing options...
Merch Guy Posted April 10, 2018 Author Report Share Posted April 10, 2018 It' got one pushrod for the clutch. Looks like it's a strip, clean and rebuild the clutch job ! Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 10, 2018 Report Share Posted April 10, 2018 On 4/10/2018 at 3:44 PM, oni nou said: Looks like that's the cause of your problem .......or I just got caught out bull****ing again[ not alone there], still I have got away with it for a good while now ......not bad for an accountant who has never even ridden a trials bike let alone taken one apart.......Its the ledger ......I just need some kind of outlet for the creative mind you see. Expand Bye, see you when you get back ... 1 Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 12, 2018 Report Share Posted April 12, 2018 On 4/10/2018 at 3:44 PM, oni nou said: Looks like that's the cause of your problem .......or I just got caught out bull****ing again[ not alone there], still I have got away with it for a good while now ......not bad for an accountant who has never even ridden a trials bike let alone taken one apart.......Its the ledger ......I just need some kind of outlet for the creative mind you see. Expand youve never ridden? Quote Link to comment Share on other sites More sharing options...
brewtus Posted April 12, 2018 Report Share Posted April 12, 2018 315Rs are notorious for "cold sticking". The Calvin Klein-priced Elf oil helps, but the best fix I ever ran across was replacing the solid steels with dimpled ones. Also makes the clutch action more progressive. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted April 13, 2018 Report Share Posted April 13, 2018 On 4/12/2018 at 12:49 PM, brewtus said: 315Rs are notorious for "cold sticking". The Calvin Klein-priced Elf oil helps, but the best fix I ever ran across was replacing the solid steels with dimpled ones. Also makes the clutch action more progressive. Expand yes Quote Link to comment Share on other sites More sharing options...
