Tlr200 fork rebuild
dazzagreener
Hi All
I have purchased my first TLR and my first twinshock. I I have stripped my forks down so the stanchions can get rechromed.
I was wondering what weight oil you use when rebuilding them and the amount that is put in each leg.
Also last of all how much psi to you put in them. I am about 85kg.
Thanks.
8 hours ago, dazzagreener said:
Hi All
Thanks.
I run 5 weight max - cc  not sure on cc but run about 5 to 10 psu just to give them a lift
I bought an oil syringe a few years ago. Ideal for gearbox and engine oil but also ideal for fior fork oil depth .
over fill fork leg - insert tube on end of syringe the correct depth  and suck . When level is correct your just sucking air
