Can't get to bleed my rear brakes
ross94
Dear all,
Rear brake pedal has no feel and just doesn't do anything. I have tried all possible ways to bleed the rear brake system but I can't get to remove the air bubbles (or at least what it seems to be the issue). Have tried normal bleeding as in pushing the pedal several times and when holding it down opening the bleed nipple but no luck - air is getting out but it's never enough. Tried pressure bleeding and even vacuum bleeding as well using a syringe and a piece of transparent pipe and also no luck one thing i noted when vacuum bleeding was that air bubbles did disappear slightly but kept on coming like it's getting air from somewhere. What could this be? Any sort of help is highly appreciated guys as this is my first trial and I can't wait to ride it.
Thanks in advance,
Ross
Check the brake master cylinder around the seal for signs of fluid leakage and corrosion. Check for signs of fluid leakage on the rear caliper around the pistons. If all appears to be clean and clear of leaks.....the seals can allow air into the circuit in some instances but no fluid escapes....Gently eases the brake pads back off the disc into the caliper and use either thin strips of plastic or alluminium to go in the gap between the pad and the disc. Make sure the caliper pistons are clean on their exposed surface before doing this. Now go through the bleed process again, fill the reservoir with fresh clean fluid...never re use fluid that’s been bled through and don’t shake the fluid container, this will aerate the fluid and it will need to settle for a long time. If the fluids been exposed to the atmosphere it will draw in moisture from the atmosphere...hygroscopic....fully synthetic fluid is less likely to be affected but nonetheless less treat with care. Is the bleed nipple creating a good seal/seat when gently nipped up home? With a clear tube attached to the nipple and the open end immersed in a small amount of fluid in a clear pot you can start to bleed. Open the nipple and operate the brake lever fully down and observe the fluid coming out of the pipe into the pot, hold the lever down and close the nipple. Repeat the process several times until no air is seen in the bleed pipe. Tighten the nipple gently. Operate the lever, you should feel resistance almost immediately. If this is the case you can now remove the pad packing and then operate the brake lever pumping the pads into contact with disc, at which point the lever should feel quite firm. Check the master cylinder push rod free play and set to man. spec. Too little free play will eventually cause the fluid to get hot, expand and force the brake into being on until it all cools down again. If this doesn’t work then I’m afraid you will need to either replace the master cylinder complete or fit a seal kit, and if there’s no improvement a caliper/seal kit, if available to you. It’s a simple circuit and blanking off the flexible pipe at the caliper end should help you eliminate one or the other. Re reading you writing, vacuum bleeding is a good method and using a syringe to bleed is a good method, providing the flex pipe, caliper and m/cylinder are in good order. Hope you sort it, let me know??
Edited by section swept
Additional script
  On 4/20/2018 at 8:14 PM, dan williams said:
Very good advice above. For what it's worth none of us likes bleeding the rear brake. It's always misery.
Expand
Jaguars with Dunlop braking systems were a real pain, taking the calipers off and holding them upside down, you would not believe the performance some systems required. I still find it hard to believe that some of the Italian superbikes need the same trick to achieve a decent brake.
Expand
They fitted calipers not specifically designed for the angle they mounted them at, that made the bleed nipple in the wrong place to purge the caliper of all the air bubbles easily.
Expand
Exactly, some dimwit had the bleed nipples on the lower half of the caliper. We used to refer to that kind of mistake as coming from the f@#£ up department. And don’t mention the handbrake, MOT testers had to make an exception for what was a secondary brake, I’d call it a wishing brake!
Expand
I have had the horrible experience of dropping out the entire back end on a v12 E type to service the handbrake caliper! what were they thinking?
Expand
THINKING now that’s a new word for them (in the past at Jaguar) to conjure with. More likely designed by committee and approved by the doorman! I used to service the XJS company car that the Aston Martin Media Manager used to run...work that one out! He wanted to know why he got rear wheel spin at 80 mph in the wet...I ask you?.. We even had a Jaguar field engineer out to confirm the car had the high ratio diff fitted...prop turns to road wheel turns multiplied by the number of stripes on the engineers tie. This car it turns out was his wife’s shopping car, he bought from us a ......wait for it.....no I’m considering my options here....wait....a....( this is like the stupid part in any games show where they build up the boredom..I mean tension)......wait I’m straining this out now......ROVER SD1 3’500 Vee 8 Van Den Plas....there I’ve said it....now did this Aston Martin Media Manager have style and panache, an accute eye for things beautiful and alluring....NOPE...never mind the fact that he wasn’t offered an Aston....any wonder Ford had to bail AM out. In another perverse world our AM salesman drove as a company car....wait for it.......wait........a.......wait...........Princess 1.7L that’s the ‘O’ series engine laddie be proud.....imagine turning up at a prospective AM buyers residence in that pile of c#@£!
  On 4/20/2018 at 9:32 PM, section swept said:
THINKING now that’s a new word for them (in the past at Jaguar) to conjure with. More likely designed by committee and approved by the doorman! I used to service the XJS company car that the Aston Martin Media Manager used to run...work that one out! He wanted to know why he got rear wheel spin at 80 mph in the wet...I ask you?.. We even had a Jaguar field engineer out to confirm the car had the high ratio diff fitted...prop turns to road wheel turns multiplied by the number of stripes on the engines tie. This car it turns out was his wife’s shopping car, he bought from us a ......wait for it.....no I’m considering my options here....wait....a....( this is like the stupid part in any games show where they build up the boredom..I mean tension)......wait I’m straining this out now......ROVER SD1 3’500 Vee 8 Van Den Plas....there I’ve said it....now did this Aston Martin Media Manager have style and panache, an accute eye for things beautiful and alluring....NOPE...never mind the fact that he wasn’t offered an Aston....any wonder Ford had to bail AM out. In another perverse world our AM salesman drove as a company car....wait for it.......wait........a.......wait...........Princess 1.7L that’s the ‘O’ series engine laddie be proud.....imagine turning up at a prospective AM buyers residence in that pile of c#@£!
Expand
No wonder our car making industry is very dead, I started in the trade in the early 80's and have had many of these "gems" pass through the workshops I have worked in, good days really, workshop life is so different now, tearing your hands to bits trying to get to a stupidly placed EGR valve etc...
When you use a vacuum bleeder (by far the best way IMHO) you will always see air bubbles in a transparent line. It's pulling a little air from between the seal of the bleeder and the tube. So don't worry about it - you will never see clear fluid in the transparent line. But it will bleed heaps faster than ANY other method.
You can purchase cheap plastic bleeder kits from EvilBay for not much, but after doing 100's of brakes over the years I can advise get one of the brass bodied pistol grip types. It is one of the best tools in our workshop, and so fast and easy. We have one in the workshop, and one in the van at events, and they are GOLD.
Expand
No change there then! I started my apprenticeship in 1966 in a small garage with three mechanics and me, and even then we reconned that after the initial design of a car was ok’d for production it was then passed to the department of sharp edges and impossible corners to hinder access or better know as the ‘cock up department’ Strangely enough in the Marine industry sport boats and upto 50 footers these to can prove to be virtually impossible to get at vital components when needed. Cam belt access on many of the latest cars and vans is dammed awkward, hurrah for the reinvention of the timing chain, and now the wet belt from Mr Ford. Keep yer tools clean???
