Andy293 Posted April 26, 2018 Report Share Posted April 26, 2018 Hi All, Does anybody know carburettor settings for a Sherpa 198 with a L2627 Mk 2 Amal? It's current setting are Slide No1, Needle 2B1(clip is fitted in the middle) , Pilot jet 20, Main jet 150, Needle jet 106 and the pilot screw is 1 and a half turns out. The bike is really boggy at low revs and won't respond to quick throttle movements, Has anybody got any ideas where to start? Thanks Andrew Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 26, 2018 Report Share Posted April 26, 2018 Start by buying a Dellorto ? 1 Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted April 26, 2018 Report Share Posted April 26, 2018 I don´t know about Bultaco Amal settings but a slide with no 1 opening.......That sounds incredibly rich. I think something between 2,5-3,5 would be normal. Throttle opening comes into effect just above idle and flattens out at approx 1/4 of opening where needle and needle jet is more important. I see Inmotion list thottle valves with 2,5 to 4 openings. 1 Quote Link to comment Share on other sites More sharing options...
Andy293 Posted April 26, 2018 Author Report Share Posted April 26, 2018 That was my first thought when I took it apart. The early Sherpa fitted with a Mk1 Amal had a 3.5 slide fitted going by my manual but I can't find any settings for a Mk2, probably because most people change them for something better. Quote Link to comment Share on other sites More sharing options...
lorenzo Posted April 26, 2018 Report Share Posted April 26, 2018 Andy - Standard slide is #3 cutaway. Of course, any carb. tuning (on this or any other bike) should be the last step in an overall tune-up - you must first ensure that everything else is OK.......... Quote Link to comment Share on other sites More sharing options...
feetupfun Posted April 27, 2018 Report Share Posted April 27, 2018 (edited) Have a close look at the hole in the needle jet. It should be round, but they wear oblong. That jet and the needle that rubs on it (the slide needle) wear very quickly and cause the symptoms you are describing, hence why people are telling you to buy a proper carburettor Edited April 27, 2018 by feetupfun 3 Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted April 27, 2018 Report Share Posted April 27, 2018 The Amal will work fine if the needle, needle jet[106] and slide[3] are all in good condition, these need to be replaced regularly depending on how much the bike is used. It is basically impossible to get the bike to run correctly if the needle jet is worn as feetup said .Pilot should be a 20/25 and main 140/150. The Bings and Amals are particularly prone to wear whereas other carbies- dellortos, mikunis, keihins aren't Cheers Greg 2 Quote Link to comment Share on other sites More sharing options...
Andy293 Posted April 27, 2018 Author Report Share Posted April 27, 2018 I've ordered a few new jets and a new slide. Thanks for your help Andy Quote Link to comment Share on other sites More sharing options...
