Sherco forks
malcolm
I have a Sherco 125 (2015). Noticed, when draining the fork oil, that the screws are different lengths but the parts diagram shows them as being the same part. Any thoughts why mine are different lengths. Also what's  the trick to tightening the screw at the bottom of the forks. Thanks.
  • 2 weeks later...
Malcolm, you need to open the top cap and turn forks upside down. On coil side this will drain most of the oil. On dampening side half of the oil will be inside cartridge and it need be disasembled to drain oil.
