Cota, 248, 1981. Gear Change Mech Eccentric Adjuster
dr nosh
Now about the eccentric adjuster. When this is assembled over the M6 stud, the adjustment made,  and the locking nut is tightened up, there is still movement in the adjuster plate.
Should the adjuster plate be locked tight in position?
If so, then the back of the eccentric adjuster is proud by 0.2mm preventing it being locked tight?
Is this correct, or have I got to machine this so its 'sub-flush' therefore allowing the adjuster plate to be locked preventing movement?
