Honda TLR /Reflex regulator and lighting
beta_blocker
Hi
I have a 1987 TLR Reflex that has had the main wiring harness and lighting removed by PO and I would like to restore minimal wiring and lighting with no battery or possibly a battery eliminator.
Stock, on the TLR Their is a regulator/rectifier under the seat and an AC regulator up behind the headlight. I've usually found one regulator/regulator on a 12v motorcycle does the job for all the lighting and charging systems and am curious why two regulators.
I'm thinking of getting a universal type reg/rectifier or possibly one from a similar model / electrical type system Honda. Has anyone done this modification for minimal lighting and if so what did you end up using?
thanks
