1994 GasGas JT25 Contact
PATRICKJEWEL
i got this barn find (1994 GasGas JT25 Contact) and had a lot of questions. what is the stock size in and out of the carburetor. Is there a aftermarket or other brand that will fit? Don't want to invest a lot, only bought for 100 bucks. Anyone know where i can find cheap part for the below list?
Missing parts:
Carberator
Throttle and tube
exhaust silencer
Hi Patrick, the standard carb would be a DellOrto PHBL 26. You should be able to pick up a throttle assy and exhaust pipe and silencer from a long time GG dealer in the states. Bye, Peter B.
  • 3 weeks later...
  • 1 month later...
It says it was a 260cc ? Do you mean that the bottom end was the same but different top or just brakes, suspension, ect. Just got the head welded and machined back, had a pebble size hole blow out in head furthest from the flow tube. The reservoir for the coolant cracked and leaked out as the original problem. I am taking apart the bottom end now having to order a special fly wheel puller than what I have. Do you know how to get a service manual for this bike? Not just the regular purchase manual or do they have one.
Do a you tube search of Jim Snell gas gas video`s. The bike is pretty much basic two stroke, except the clutch pressure plate only goes back on one way. It is marked with a notch if my memory is right.
  • 1 year later...
